Thinking about making a jump in tire size |
Woody |
Nov 6 2012, 06:06 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Im currently running the 205s and 225s Hankook Z214 AX tires. Even in the middle of the Texas summers they never overheated if I kept the pressures under 24 psi hot. Im wondering if running 225/45/15 front and 275/35/15 rear Hoosier A6s would be more of a detriment because the car is so light or should I just stick with the current size. I do have room for them under the fenders. The car is still an angry 2056 but will hopefully get a bump to 2270 or 2316 this winter. Thoughts?
Woody |
Nov 30 2012, 07:08 AM
I wonder how much tire and suspension flex will be going on. Maybe I should order some 15mm spacers just in case.
J P Stein |
Nov 30 2012, 08:47 AM
I wonder how much tire and suspension flex will be going on. Maybe I should order some 15mm spacers just in case. A bunch, see pic....note outside rear tire. I had around 5 inches of backspace on the rear wheels, no spacers. You'll also need longer wheel studs/bolts. Attached image(s) |
Lo-Fi Version | Time is now: 12th June 2024 - 12:54 AM |
