> Engine wash
914itis
post Dec 11 2012, 02:28 PM
What do we use to was the engine while mounted on the car? I am tryng to clean up my engine , it's not too bad , just small grease and dust. Nothing too bad but the thins were painted with high heat spray previously . Ideas???
bigkensteele
post Dec 11 2012, 11:06 PM
Major Member
Do you still have the sound deadening pad on your firewall? If so, I would remove that since it traps water, whatever you clean with. I really like simple green as it cuts through light grease and doesn't leave much residue. Underside, I would take the rear valence off, drive the car to a self service car wash with a roll of quarters, a can of Gunk, a pair of ramps and a change of clothes. You will need the valence off to back up on the ramps. You will need the Gunk because their degreaser won't cut it. The quarters and the change of clothes are obvious.
914outlaw
post Dec 12 2012, 01:27 PM
Dave
QUOTE(bigkensteele @ Dec 12 2012, 12:06 AM) *
If you clean off the gunk on the bottom of the engine at most self service car washes and it goes down the drain, it will end up in the water supply. If someone sees you and calls the police, you can get in trouble.
- Lo-Fi Version Time is now: 15th March 2026 - 05:45 AM
