> wheel spacers - what do you like?, fronts need 1", rears about 2"
tadink
post Dec 12 2012, 02:50 PM
Hi guys -
did a search on wheel spacers and got millions of hits but no answers....so I'll post this up. Where do you find good wheel spacers, and what are the pro's and con's of doing the various options?
for the width I'm looking for - it seems there is a "bolt on" that does not need new wheel studs, or the spacers that have longer wheel studs passing thru them. I've gone with a 5-lug drilled into the 4 lug hubs....
I was surprised at the weight of the 2" spacers 'bolt on', like 6+ lbs each?!
Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site.
thoughts and knowledge sharing very appreciated!
cheers
td
Eric_Shea
post Dec 12 2012, 03:02 PM
PMB Performance
FWIW... I like 944 spacers. I've stacked a few and custom machined them for the desired thickness:
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1355346176.1.jpg)
tadink   wheel spacers - what do you like?   Dec 12 2012, 02:50 PM
Eric_Shea   What wheels? What offset? What fenders? 1...   Dec 12 2012, 02:56 PM
tadink   What wheels? What offset? What fenders? 1...   Dec 12 2012, 03:02 PM
Eric_Shea   FWIW... I like 944 spacers. I've stacked a f...   Dec 12 2012, 03:02 PM
tadink   FWIW... I like 944 spacers. I've stacked a ...   Dec 12 2012, 03:05 PM
SirAndy   Currently I'm leaning towards the 54MM, Weltme...   Dec 12 2012, 03:06 PM
tadink   Currently I'm leaning towards the 54MM, Weltm...   Dec 12 2012, 03:38 PM
SirAndy   only DE events and AX are intended, mostly street...   Dec 12 2012, 03:40 PM
John Jentz   only DE events and AX are intended, mostly stree...   Dec 13 2012, 11:15 AM
SirAndy   Is that a local rule on the west coast? That is a...   Dec 13 2012, 12:24 PM
underthetire   I bought some from this guy http://www.ebay.com/it...   Dec 12 2012, 03:08 PM
bulitt   I bought some from this guy http://www.ebay.com/i...   Dec 12 2012, 08:00 PM
SirAndy   As you can see, i very much prefer the longer stud...   Dec 12 2012, 03:14 PM
Eric_Shea   So you'll have 914 calipers and solid rotors...   Dec 12 2012, 03:42 PM
tadink   "don't waste money along the way?!...   Dec 12 2012, 05:18 PM
SirAndy   Now, about these 944 spacers - am I correct in see...   Dec 12 2012, 05:54 PM
Eric_Shea   Sorry... misread... the A.I.R. flares.   Dec 12 2012, 03:45 PM
jmmotorsports   iuseHAND R BOLTON TYPE NEVER HAD A PROBLEM WITH T...   Dec 12 2012, 04:43 PM
matthepcat   I used 100mm studs and 944 spacers. They are light...   Dec 12 2012, 04:46 PM
Woody   :agree: 944 spacers.   Dec 12 2012, 05:01 PM
McMark   From my inspection of the '2012 PCA Club Racin...   Dec 13 2012, 02:46 PM
Elliot Cannon   Two inch slip on spacers over 100mm studs puts a l...   Dec 13 2012, 05:33 PM
John Jentz   Two inch slip on spacers over 100mm studs puts a ...   Dec 13 2012, 05:42 PM
SirAndy   Two inch slip on spacers over 100mm studs puts a...   Dec 13 2012, 06:52 PM
McMark   But the rear doesn't have a ring. And early fr...   Dec 13 2012, 07:02 PM
SirAndy   But the rear doesn't have a ring. And early fr...   Dec 13 2012, 07:53 PM
- Lo-Fi Version Time is now: 2nd November 2026 - 09:44 AM
