| tadink |
Dec 12 2012, 02:50 PM
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Hi guys -
did a search on wheel spacers and got millions of hits but no answers....so I'll post this up. Where do you find good wheel spacers, and what are the pro's and con's of doing the various options? for the width I'm looking for - it seems there is a "bolt on" that does not need new wheel studs, or the spacers that have longer wheel studs passing thru them. I've gone with a 5-lug drilled into the 4 lug hubs.... I was surprised at the weight of the 2" spacers 'bolt on', like 6+ lbs each?! Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. thoughts and knowledge sharing very appreciated! cheers td |
| SirAndy |
Dec 12 2012, 03:06 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,560 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. Street driving only or do you plan to do some track time? If track time is in your future, the bolt on "spacers" are *not* legal with any racing organization. Longer studs are easy to obtain and installed and the spacers for them (like the 944 spacers above) are much lighter and simple to install and change. (IMG:style_emoticons/default/driving.gif) |
| tadink |
Dec 12 2012, 03:38 PM
Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. Street driving only or do you plan to do some track time? If track time is in your future, the bolt on "spacers" are *not* legal with any racing organization. Longer studs are easy to obtain and installed and the spacers for them (like the 944 spacers above) are much lighter and simple to install and change. (IMG:style_emoticons/default/driving.gif) thanks - re: track time - only DE events and AX are intended, mostly street time. TD |
tadink wheel spacers - what do you like? Dec 12 2012, 02:50 PM
Eric_Shea What wheels? What offset? What fenders? 1... Dec 12 2012, 02:56 PM
tadink
What wheels? What offset? What fenders? 1... Dec 12 2012, 03:02 PM
Eric_Shea FWIW... I like 944 spacers. I've stacked a f... Dec 12 2012, 03:02 PM
tadink
FWIW... I like 944 spacers. I've stacked a ... Dec 12 2012, 03:05 PM
only DE events and AX are intended, mostly street... Dec 12 2012, 03:40 PM
John Jentz
only DE events and AX are intended, mostly stree... Dec 13 2012, 11:15 AM
SirAndy Is that a local rule on the west coast?
That is a... Dec 13 2012, 12:24 PM
underthetire I bought some from this guy
http://www.ebay.com/it... Dec 12 2012, 03:08 PM
bulitt
http://www.ebay.com/i... Dec 12 2012, 08:00 PM
SirAndy As you can see, i very much prefer the longer stud... Dec 12 2012, 03:14 PM
Eric_Shea
So you'll have 914 calipers and solid rotors... Dec 12 2012, 03:42 PM
tadink
"don't waste money along the way?!... Dec 12 2012, 05:18 PM
SirAndy Now, about these 944 spacers - am I correct in see... Dec 12 2012, 05:54 PM
Eric_Shea
Sorry... misread... the A.I.R. flares. Dec 12 2012, 03:45 PM
jmmotorsports iuseHAND R BOLTON TYPE NEVER HAD A PROBLEM WITH T... Dec 12 2012, 04:43 PM
matthepcat I used 100mm studs and 944 spacers. They are light... Dec 12 2012, 04:46 PM
Woody :agree: 944 spacers.
Dec 12 2012, 05:01 PM
McMark From my inspection of the '2012 PCA Club Racin... Dec 13 2012, 02:46 PM
Elliot Cannon Two inch slip on spacers over 100mm studs puts a l... Dec 13 2012, 05:33 PM
John Jentz
Two inch slip on spacers over 100mm studs puts a ... Dec 13 2012, 05:42 PM
Two inch slip on spacers over 100mm studs puts a... Dec 13 2012, 06:52 PM
McMark But the rear doesn't have a ring. And early fr... Dec 13 2012, 07:02 PM
SirAndy But the rear doesn't have a ring. And early fr... Dec 13 2012, 07:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 09:45 AM |
