| tadink |
Dec 12 2012, 02:50 PM
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Hi guys -
did a search on wheel spacers and got millions of hits but no answers....so I'll post this up. Where do you find good wheel spacers, and what are the pro's and con's of doing the various options? for the width I'm looking for - it seems there is a "bolt on" that does not need new wheel studs, or the spacers that have longer wheel studs passing thru them. I've gone with a 5-lug drilled into the 4 lug hubs.... I was surprised at the weight of the 2" spacers 'bolt on', like 6+ lbs each?! Currently I'm leaning towards the 54MM, Weltmeister Turbo Star Wheel Spacer - found a pair on paragon for $144.....compared to $146 EACH for the bolt on version on the bird site. thoughts and knowledge sharing very appreciated! cheers td |
| Eric_Shea |
Dec 12 2012, 03:42 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I've got stock 914 4 lug hubs drilled for 5-lug So you'll have 914 calipers and solid rotors under all of that meat? (IMG:style_emoticons/default/ohmy.gif) Doable but, as Andy mentions, it really depends upon your intended use. When you mentioned the Sheridan kit and the wide rubber, I thought you might be racing the car but, with drilled 4 stuff, it appears to be more of a street car. The rears are fine being drilled but again, you're limiting yourself to 914 components attached to 935 wheels and tires. (IMG:style_emoticons/default/wink.gif) (914 rear hubs only allow 914 CV joints). If your fronts are drilled 914 rotors then you can really only work with 914 calipers and solid rotors. You can use a 911 caliper without spacers if it's an early 914 rotor but there's no real gain. Again, all this can be done if all you want is a cool looking street car and you don't plan to put a motor in it that is commensurate to the body kit and the tire size. Let us know what you're plans are and we can help guide you so you don't waste money along the way. (IMG:style_emoticons/default/beer.gif) |
tadink wheel spacers - what do you like? Dec 12 2012, 02:50 PM
Eric_Shea What wheels? What offset? What fenders? 1... Dec 12 2012, 02:56 PM
tadink
What wheels? What offset? What fenders? 1... Dec 12 2012, 03:02 PM
Eric_Shea FWIW... I like 944 spacers. I've stacked a f... Dec 12 2012, 03:02 PM
tadink
FWIW... I like 944 spacers. I've stacked a ... Dec 12 2012, 03:05 PM
SirAndy Currently I'm leaning towards the 54MM, Weltme... Dec 12 2012, 03:06 PM
tadink
Currently I'm leaning towards the 54MM, Weltm... Dec 12 2012, 03:38 PM
only DE events and AX are intended, mostly street... Dec 12 2012, 03:40 PM
John Jentz
only DE events and AX are intended, mostly stree... Dec 13 2012, 11:15 AM
SirAndy Is that a local rule on the west coast?
That is a... Dec 13 2012, 12:24 PM
underthetire I bought some from this guy
http://www.ebay.com/it... Dec 12 2012, 03:08 PM
bulitt
http://www.ebay.com/i... Dec 12 2012, 08:00 PM
SirAndy As you can see, i very much prefer the longer stud... Dec 12 2012, 03:14 PM
tadink
"don't waste money along the way?!... Dec 12 2012, 05:18 PM
SirAndy Now, about these 944 spacers - am I correct in see... Dec 12 2012, 05:54 PM
Eric_Shea
Sorry... misread... the A.I.R. flares. Dec 12 2012, 03:45 PM
jmmotorsports iuseHAND R BOLTON TYPE NEVER HAD A PROBLEM WITH T... Dec 12 2012, 04:43 PM
matthepcat I used 100mm studs and 944 spacers. They are light... Dec 12 2012, 04:46 PM
Woody :agree: 944 spacers.
Dec 12 2012, 05:01 PM
McMark From my inspection of the '2012 PCA Club Racin... Dec 13 2012, 02:46 PM
Elliot Cannon Two inch slip on spacers over 100mm studs puts a l... Dec 13 2012, 05:33 PM
John Jentz
Two inch slip on spacers over 100mm studs puts a ... Dec 13 2012, 05:42 PM
Two inch slip on spacers over 100mm studs puts a... Dec 13 2012, 06:52 PM
McMark But the rear doesn't have a ring. And early fr... Dec 13 2012, 07:02 PM
SirAndy But the rear doesn't have a ring. And early fr... Dec 13 2012, 07:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 09:44 AM |
