> Where to clean and where to lube, injector trigger points
jsayre914
post Aug 19 2012, 04:01 PM
Speed Up !!!
Can you show me on this picture where you would clean, and with what.
Also where to lubricate and with what.
Thanks
john rogers
post Dec 14 2012, 04:07 PM
In all the years we had a 2L with trigger points (10?), we never found cleaning/lubing/etc to them did anything. The only thing that worked was putting in new ones and generally that was done after everything else was adjusted, poked, replaced, etc and the problem never went away but new points "magically" fixed it! This may be against what many will say but the replacement ALWAYS fixed the problem.
Since you said the O2 dropped low, I would suggest installing a fuel pressure gauge and run it up through the engine lid so someone can watch it. The engine is a bit larger and it sounds like to me there is not enough fuel being caused by pressure surges. We used a gauge that was left in all the time and now and then I would run the pressure up and down just to "clean out" the pressure regulator. Seemed to help.
A note, if you unplug anything, make sure the hoses are well plugged so an air leak does not mask the issue.
jsayre914   Where to clean and where to lube   Aug 19 2012, 04:01 PM
914Sixer   I would probably just wipe them out good. Spray s...   Aug 19 2012, 07:45 PM
Dave_Darling   Clean the metal contact bits. Clean the plastic r...   Aug 20 2012, 12:35 AM
jsayre914   Im not sure if its alignment or what. I am still g...   Dec 12 2012, 03:17 PM
914itis   Joe, Did you check the vacuum advance on the dizzy...   Dec 12 2012, 04:13 PM
porschepartguy   I have NOS, Bosch # 1 230 090 000 trigger points. ...   Dec 12 2012, 04:20 PM
The Cabinetmaker   Save your hundred bucks. What you describe is not ...   Dec 12 2012, 04:39 PM
sfrenck   Save your hundred bucks. What you describe is not...   Dec 12 2012, 04:48 PM
The Cabinetmaker   Bucking is almost always caused by a rich fuel con...   Dec 12 2012, 05:26 PM
jsayre914   Bucking is almost always caused by a rich fuel co...   Dec 12 2012, 05:31 PM
mepstein   Bucking is almost always caused by a rich fuel co...   Dec 13 2012, 09:50 PM
jsayre914   Hey, i was just thinking. Its been about 3000 mile...   Dec 13 2012, 04:42 PM
McMark   Didn't see anyone mention TPS. Try unplugging...   Dec 14 2012, 03:34 PM
john rogers   In all the years we had a 2L with trigger points (...   Dec 14 2012, 04:07 PM
jsayre914   In all the years we had a 2L with trigger points ...   Dec 14 2012, 04:13 PM
porschepartguy   Hey Joseph, My partner will be at the shop tomorr...   Dec 14 2012, 08:06 PM
Dave_Darling   If you have access to an oscilloscope, you can sco...   Dec 14 2012, 10:18 PM
- Lo-Fi Version Time is now: 15th April 2026 - 01:14 PM
