> Gas in Oil, Lots of gas in the oil
sbruzek
post Dec 9 2012, 06:41 PM
I've been trying to get a 1973 2.0 L to run. Its still got the original FI. I've replaced a bunch of parts. New plugs, points, wires, cap, rotor, coil, FI seals, the fuel pump, fuel filter, rebuild the relay board, swapped out the in line fuel pressure regulator (today) tested and now have 28 psi of fuel, and replaced all the vacum lines. I've tested the manifold pressure sensor and it holds a vacum and the resistance across the connector test out OK.
Like before most this work she will start right up cold, but run very rough and blow smoke, it will not idle, and stall after 3-4 minutes and then not restart. Looking into the throttle body its loaded with gas. I got it to run today for 10 minutes or so and it dumped about a quart of gas into the oil. I know how much because I had to drain the oil aftre seeing an oil leak from a valve cover. Leaking oil was very thin and full of gas. Amount drained out was 1 qt higher than I put in. This also happened last time I tied to get her started, gas in oil. It started better this time with repalce FPR but still large amounts of gas in the oil. It happens each time I try to get the 2.0 running. All the work and replaced parts so far have not solved the issue, mainly gas in oil, and running way to rich/stalling. The excess gas has to be the cause of everthing I would think.
I've already pulled the injectors and the cold start valve to see if any where stuck open and none were. It would seem that the extra gas can only be coming from the injectors or the cold start. I continue to suspect the cold start based on all the gas up in the throttle body under the air cleaner. Could the gas be shooting way up there from one or all the injectors??? Could something be telling the injectors to add that much gas?? It like its getting way to much gas ALL the time. Now it will rev high right away when you get air into the throtle body. It also did that when the cold start was off and open to let extra air in.
Any ideas??
Could a bad heat temp sensor cause this much gas to get injected?? It tests out OK and it happens with or without it conncted. How about the CU or throttle switch??
Any help would be appreciated.
McMark
post Dec 16 2012, 06:28 PM
914 Freak!
It can be replaced with the intake in place. Get the deepest 13mm socket you can find, coil the wire up inside and use a 6" extension (I think).
I had an engine that had totally erratic stall out problems. Turned out the CHT was shorting out internally. Either replace the CHT and check the wire, or check the resistance as described on Brad Anders site.
914_teener
post Dec 16 2012, 06:37 PM
QUOTE(McMark @ Dec 16 2012, 04:28 PM) *
+1 with what Mark said.
Also you may want to check the harness at the ECU plug to make sure the harness is not shorted out.
sbruzek   Gas in Oil   Dec 9 2012, 06:41 PM
ConeDodger   Is your CHT unplugged? Obviously, you're runni...   Dec 9 2012, 06:51 PM
sbruzek   CHT is plugged in. I've not done a compressi...   Dec 9 2012, 06:57 PM
914_teener   CHT is plugged in. I've not done a compress...   Dec 9 2012, 07:47 PM
Black22   My 1.8L did this when I first got it. One of my in...   Dec 9 2012, 07:46 PM
aircooledtechguy   You've got a stuck injector(s). The motor wil...   Dec 9 2012, 07:48 PM
bandjoey   and change the oil twice to flush out that much ga...   Dec 9 2012, 09:34 PM
sbruzek   thanks to who replied   Dec 10 2012, 06:44 PM
brant   make sure you pull all 5 injectors to run that tes...   Dec 11 2012, 11:14 AM
sbruzek   make sure you pull all 5 injectors to run that te...   Dec 16 2012, 08:02 AM
brant   what happens if you key the power on but don't...   Dec 16 2012, 10:39 AM
sbruzek   what happens if you key the power on but don...   Dec 16 2012, 02:51 PM
McMark   Getting them cleaned and checked it a great thing ...   Dec 16 2012, 05:03 PM
sbruzek   Getting them cleaned and checked it a great thing...   Dec 16 2012, 05:29 PM
sbruzek   Getting them cleaned and checked it a great thin...   Dec 16 2012, 05:49 PM
brant   I would also do a vacuum test on the MPS Mark is ...   Dec 16 2012, 05:27 PM
brant   you can replace it without removing the runners......   Dec 16 2012, 06:27 PM
McMark   It can be replaced with the intake in place. Get ...   Dec 16 2012, 06:28 PM
914_teener   It can be replaced with the intake in place. Get...   Dec 16 2012, 06:37 PM
sbruzek   It can be replaced with the intake in place. Get...   Dec 16 2012, 07:06 PM
Dave_Darling   I believe that I usually use a 6" extension. ...   Dec 16 2012, 07:14 PM
toadman   I am not a mechanic but it seems that, if an intak...   Dec 16 2012, 07:35 PM
sbruzek   The new CHT sender and new in line resistor solved...   Jul 15 2013, 06:25 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:41 AM
