| stugray |
Dec 17 2012, 10:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am adjusting the valve geometry while putting in a Raby 9700 cam and I am seeing .38 on the exhaust cam lift and .496 at the valve (an exh rocker ratio of 1.3) and I have a .39 on the intake with a .546 at the valve ( an int rocker ratio of 1.4) is this what everyone else gets for rocker ratios:
Intake rocker ratio = 1.4 Exhaust rocker ratio = 1.3 These are the 1.7 (1.8?) rockers that accept the 911 swivel feet. I am using the swivel feet, have modified the rocker faces, adjustable push rod, and zero lash to do the meaurements. Do those rocker ratios look like stock? I want to take 50 thousandths off the Combustion chambers to increase the CR, but my measurements say I wont have enough clearance on the Intake valve once I shave off 50 thousandths. I only have ~0.075 clearance now from the piston to the Int valve as it is with a deck of 0.030 and everything else (crank & rods) stock - flat top 96mm pistons. That Intake valve travel of ~0.55 looks huge to me. Anyone else care to comment? Stu |
| stugray |
Dec 18 2012, 12:08 PM
Dave - So is it possible to find an intake rocker with a ratio of 1.3?
Or are all intake rockers going to be 1.4? The .550 intake valve lift seems like a LOT. I didnt want to have to relieve my pistons for clearance if I could avoid it. Edwin - I will probably give them a call. Someone here stated that Jake's cams are just rebranded from someone else - anyone remember who that was? ( I seem to recall webcam). I would prefer to give them a call. Stu |
stugray What rocker arm ratios do people see? Dec 17 2012, 10:26 PM
Dave_Darling The stock ratios range from 1.3 to 1.4, so you... Dec 17 2012, 11:29 PM
edwin Call European machine works?
They've helped in... Dec 17 2012, 11:38 PM
Dave_Darling
Dave - So is it possible to find an intake rocker... Dec 18 2012, 06:02 PM
monkeyboy I believe WebCam actually makes them, but they are... Dec 18 2012, 12:32 PM
brant I too believe they are built to order...
custom o... Dec 18 2012, 12:41 PM
Mark Henry
custom ... Dec 18 2012, 12:45 PM
bobhasissues When you say "at the valve" are you actu... Dec 18 2012, 06:23 PM
stugray bob -
Yes - and simultaneously at the pushrod t... Dec 18 2012, 07:22 PM
bobhasissues Stu,
Nobody will try to help you if you continue ... Dec 18 2012, 09:40 PM
stugray
Stu,
Nobody will try to help you if you continue... Feb 10 2013, 11:07 PM
bobhasissues Bob, now that we have established that these rocke... Feb 11 2013, 08:15 PM
stugray bob-
I see nowhere in the previous post that co... Dec 18 2012, 11:01 PM
Racer Chris I'll gladly trade you a set of 1.3 ratio, 1.7L... Dec 18 2012, 11:44 PM
Mark Henry Dude the reason I don't help you is simple....... Dec 18 2012, 11:50 PM
stugray
That's funny because it says Type IV store r... Dec 19 2012, 08:27 AM
Racer Chris
I am also reading on Jakes cam instructions that ... Dec 19 2012, 10:10 AM
Jeff Hail
I am also reading on Jakes cam instructions that... Feb 4 2015, 11:39 PM
Mark Henry
[quote name='Racer Chris' post='1786713' date='De... Feb 5 2015, 06:27 AM
r_towle post a picture of the cam card.
It will possibly g... Dec 19 2012, 09:13 AM
stugray rich,
Thanks. I will scan the card & post it ... Dec 19 2012, 09:33 AM
stugray
I will take pictures tonight.
I measure .388 Cam... Dec 19 2012, 11:42 AM
nathansnathan "Valve lift" is taking the ratio of the ... Dec 19 2012, 11:50 AM
stugray I will get pics of the test rig after dinner, but ... Dec 19 2012, 07:04 PM
Todd Enlund
And BTW - I fully profiled the cam myself, and th... Dec 27 2012, 02:22 AM
Racer Chris
And BTW - I fully profiled the cam myself, and t... Dec 27 2012, 05:55 AM
r_towle I am confused.
You have not milled out your heads ... Dec 19 2012, 07:41 PM
stugray
Not exactly - I am measuring how much clearance ... Dec 19 2012, 08:43 PM
stugray Some pics:
Pics of setup to measure deck height:
... Dec 19 2012, 09:02 PM
nathansnathan My experience with it was that it was easy to get ... Dec 19 2012, 11:42 PM
stugray
I have taken ~.060 off the rocker faces and coun... Dec 20 2012, 12:02 AM
nathansnathan
I have taken ~.060 off the rocker faces and cou... Dec 20 2012, 08:36 AM
Racer Chris Stu,
Is it possible the ratio was altered by remac... Dec 20 2012, 10:02 AM
stugray Racer Chris,
I measured all 4 of them, Valve lift... Dec 22 2012, 04:09 PM
stugray Ok, so after some measurements, I get the whole ... Dec 23 2012, 06:29 PM
stugray Two more questions:
1 - When some of you have had... Dec 24 2012, 04:51 PM
nathansnathan
And nathansnathan
How is that possible? Regard... Dec 30 2012, 06:02 PM
wndsrfr
2 - Who has a good selection of rocker shims?
... Dec 30 2012, 07:26 PM
stugray Quick bump so racer chris doesnt forget about me ;... Dec 26 2012, 05:17 PM
Racer Chris
Quick bump so racer chris doesnt forget about me ... Dec 26 2012, 07:10 PM
tscrihfield stu,
if i could lend some advice. I would not adv... Dec 26 2012, 07:17 PM
nathansnathan I've given it more thought their and edited ab... Dec 30 2012, 10:02 PM
stugray So I had the engine case "decked", the r... Feb 10 2013, 05:11 PM
nathansnathan It sounds to me like you are doing something wrong... Feb 10 2013, 06:44 PM
stugray :confused: Feb 10 2013, 10:54 PM
Racer Chris It is not possible that you are the first to disco... Feb 10 2013, 11:05 PM
stugray
Chris - I had three reputable machine heads sit ... Feb 10 2013, 11:13 PM
barefoot
Chris - I had three reputable machine heads sit... Dec 7 2015, 04:34 PM
stugray
Chris - I had three reputable machine heads si... Dec 7 2015, 07:31 PM
barefoot
[quote name='stugray' post='1818427... Dec 7 2015, 08:50 PM
Racer Chris The cam card says the valve lift is .368".
Yo... Feb 11 2013, 12:03 AM
stugray Chris,
That's right. I need to remeasure the ... Feb 11 2013, 07:51 AM
worn
Chris,
That's right. I need to remeasure the... Feb 11 2013, 10:30 AM
stugray I just spoke with one of the Type-IV experts at Fa... Feb 11 2013, 02:11 PM
stugray Bob I " will build a grenade, that's why ... Feb 12 2013, 02:40 PM
stugray Ok, so I decided to go with a webcam 86b instead o... Mar 26 2013, 08:25 PM
worn
Ok, so I decided to go with a webcam 86b instead ... Mar 27 2013, 09:38 AM
nathansnathan
So apparently Webcam knows that these rockers are... Mar 27 2013, 11:09 AM
stugray My plan is to set the intake right at the "ad... Mar 27 2013, 12:13 PM
worn
My plan is to set the intake right at the "a... Mar 27 2013, 02:09 PM
stugray I have found (after testing 8 sets of rockers) tha... Mar 27 2013, 03:29 PM
stugray So I put in the new webcam 86b.
Advertised lift i... Mar 31 2013, 03:14 PM
stugray Just finished the "Clay on the Piston" t... Mar 31 2013, 03:26 PM
stugray One observation that I made:
When measuring the w... Apr 1 2013, 09:55 AM
stugray Important lesson learned!
I cut the pushrods ... Apr 3 2013, 12:20 PM
worn
I cut the pushrods... Apr 3 2013, 03:22 PM
Jake Raby
So much for us just repackaging things and selli... Apr 3 2013, 06:43 PM
worn
Not even Web Cam knows what we do to camshafts... Apr 4 2013, 10:35 AM
stugray Jake
I have promoted your hardware often, even a... Apr 3 2013, 09:39 PM
Jake Raby
Jake
I have promoted your hardware often, even ... Apr 4 2013, 05:45 PM
stugray Jake, the above quote was merely an exact comment ... Apr 4 2013, 09:21 PM
stugray After going through all of this measuring and havi... Apr 29 2013, 01:31 PM
stugray Bump the above question for rdauenhauer.
Jake? Ty... Feb 4 2015, 02:21 PM
rdauenhauer I missed this. Good read. Feb 4 2015, 03:19 PM
Dave_Darling The ratio of all of the stock rockers "should... Dec 7 2015, 05:30 PM
Steve Pratel :rotfl: Really? come on guys let it go already. Dec 7 2015, 08:54 PM
stugray
... Dec 7 2015, 09:43 PM
Superhawk996
... Jan 9 2022, 08:18 AM
930cabman What is the consensus from this dramatic post? can... Jan 8 2022, 06:14 PM
iankarr I used Jake's method as the basis for my video... Jan 9 2022, 09:52 AM
930cabman
I used Jake's method as the basis for my vide... Jan 9 2022, 10:34 AM
iankarr Please don’t do THAT lol. Jake’s method, yesâ€... Jan 9 2022, 10:43 AM
Mark Henry There's always going to be variants of small d... Jan 9 2022, 11:50 AM
930cabman Exactly, overthinking can be problematic. Part of ... Jan 9 2022, 04:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th October 2026 - 01:19 AM |
