Carl |
Ummm ... what? ![]() ![]() ![]() Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California ![]() |
I'm trying to lean out a car that goes through gas like a drunken sailor. To start the process, I want to convert the carbs back to the original factory jetting then address the performance issues if that setting is too lean. Hopefully, there are authorities on carbs out there that know the answers to the following questions:
/6's came with Weber 40IDT3C's, as did the 911T (same engine). The /6 factory manual says the jetting should be: 45 idle jets 105 mains 170 air jets F1 emulsion tubes The Pat Braden book on Weber's has the following jetting for 40IDT3C's for the 911T: 50 idles 110 mains 185 airs F2 emulsion tubes Which is correct factory jetting for the 914/6? There are different jetting arrangements for 40IDA3C's. Braden says the IDA's were on the 911L engine. Were they used on other P engines? There are more references to IDA's in the printed material than IDT's. This doesn't make sense to me if they only came on 911L's because there weren't a lot of them produced vs the 911T's. What are the differences between the IDA's and IDT's? The external appearance is the same but the jetting is different for engines of the same displacement. The engine in my car has a 911T crank and case with a 2L 911E pistons, cyls & cams. The 911E was an MFI engine. I've been told there are differences between cams for MFI engines vs carbs. Is this true? If so, how are they different? Should my engine be jetted differently because of it? and finally, how come a dropped nut will always land in a location that's the most difficult to see, reach, or both? (IMG:style_emoticons/default/idea.gif) Thanks for the help. |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,631 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Definitely double check the main venturis/chokes as that makes a huge difference in how much top-end the car makes, and where it is made. IIRC the stock 914-6/2.0T had 27mm venturis. I have 32mm's in my 2.2"S/T" and full race motors usually run 34's or bigger. The wrong choice can just kill your A/F and drivability.
Lo-Fi Version | Time is now: 3rd July 2025 - 01:29 PM |
