> 73 2.0L Idle problem
cwpeden
post Dec 26 2012, 01:34 AM
Great White North, huh?
I'm trying to help a friend solve an idle problem. Idle is low to the point of stalling and backfiring.
Here's what we have tryied so far:
Grounds are good
Timing is good
Dwell is a litlle high
Vacuum hoses are good
Cyl head temp sensor good
Ballast resistor good
Points good
Cap good
rotor good
Been through two trobleshooting guides with no results.
Need help figuring out a peculiar problem. When I take the vac lines off the dist I get the the usual high revs but they dont go away when the lines are plugged. Could this be a symptom of a bad vac can on the dist?
Any thoughts
914itis
post Dec 26 2012, 05:44 AM
Was timing set with the vac lines plugged? Try to cap the vac lines going to the dizzy and report back.
- Lo-Fi Version Time is now: 29th April 2026 - 07:04 PM
