PDXMike |
Slowly Learning ![]() ![]() Group: Members Posts: 112 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest ![]() |
I opened up my previously chattering clutch today. The pressure plate is all nicked up. I guess I shouldn't be surprised, engaging the clutch felt pretty much the same way this looks. But given that the clutch disk isn't THAT worn, I don't see how this is possible. It looks like somebody went at it on purpose with a cold chisel.
Is it just likely that a previous PO replaced the disk and put it back together like this? Is there something else wrong that needs to be addressed? ![]() ![]() Mike |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
I agree it looks like you had something foreign stuck between the plate & Clutch. Every time you engaged it would move to a different spot? That is pretty wild though (IMG:style_emoticons/default/confused24.gif) . I can't say I have ever seen one like that either. Anything fall out when you pulled it? That clutch disc is sure missing some meat on the one lip. Looks like a good 3/8" has worn off the one edge. If you need anything I have a few spares. Your welcome to them if you drive down to pick them up (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 3rd July 2025 - 01:37 AM |
