> Crapity Crap!, LED lights offer NO "improvement"
Qarl
post Jun 21 2004, 07:38 PM
Shriveled member
I received the LED prototypes in today. Red, Blue, and Superbright white. The superbright white is really just a wavelength of blue.
I can honestly say they are not any brighter than the incandescent bulbs. The good news is that the inverted lense actually disperses the light about the same as the incandescent bulb, thus doing away with problem that the LED lights are directional in natuure.
I think that the size of the LED is the issue. I big LED will most definitely be brighter, but you run into size problems with the lamp base.
It has only three advantages I can think of.
1. Last longer
2. Color choices
3. Will not fade and yellow over time.
So... I don't think it is really worth going through the expense of importing some in from overseas.
Sorry to get everyone's hopes up. I guess that's part of the experimentation process.
I am still waiting to hear back about the halogen fog bulbs though.
Qarl
post Jun 21 2004, 07:51 PM
Shriveled member
Supposedly they have the resistor integrated to be compatible with automotive electrical systems. Not sure about the "peak" voltage issue.
I ran them from 12 volts and also from 9 volts (just to see) and couldn't tell any difference in brightness.
As far as providing power to them, I tried two methods... using the gauge body as ground and postive voltage to the end of the light.
I also tried a different bulb receptical with seperate postive and negative leads.
Qarl   Crapity Crap!   Jun 21 2004, 07:38 PM
jkeyzer   Do the lamps have external current limiting resist...   Jun 21 2004, 07:43 PM
Qarl   If anybody wants some from a source here in the U....   Jun 21 2004, 07:48 PM
Qarl   Supposedly they have the resistor integrated to be...   Jun 21 2004, 07:51 PM
Qarl   I can get ANY type of bulb made. Xenon, halogen, ...   Jun 21 2004, 07:59 PM
Qarl   Unfortunately, my digital camera doesn't take ...   Jun 21 2004, 08:00 PM
Qarl   Here is the tachy It is actually brighter than in...   Jun 21 2004, 08:00 PM
Qarl   blue   Jun 21 2004, 08:03 PM
balthazar   Hi! Just thought I'd post some pix of an ...   Jun 21 2004, 08:28 PM
balthazar   Here is another picture...They are plenty bright e...   Jun 21 2004, 08:31 PM
balthazar   I used regular phone wire. (1)Once the soldering...   Jun 21 2004, 08:57 PM
balthazar   Here's how it looks without the shrink tubing....   Jun 21 2004, 08:59 PM
Qarl   There are lots of possibilities for this. I was ju...   Jun 21 2004, 09:05 PM
campbellcj   FWIW I think the main reason some new cars use LED...   Jun 21 2004, 09:10 PM
balthazar   I am going to make a taillight assembly with progr...   Jun 21 2004, 09:33 PM
Lawrence   Did Andy take pictures for you? :D -Rusty :toke...   Jun 21 2004, 11:27 PM
dmenche914   The regular lights in the instruments seem bright ...   Jun 22 2004, 12:15 AM
nein14   I know they're pricey, but has any one used th...   Jun 22 2004, 07:10 AM
PorscheTom   Sorry to hear about your findings. I've used ...   Jun 22 2004, 10:06 AM
Qarl   I am awaiting the response from the real manufactu...   Jun 22 2004, 12:16 PM
!   Hmmmm, do they work in the wheel wells? :shades:   Jun 22 2004, 03:24 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:54 AM
