> flapper box heater attachment - RESOLVED!, with help from this board - many thanks!!!!
tadink
post Jan 5 2013, 04:03 PM
hi guys -
I'm under the car trying to hook up my heater system - but the wire cable connector from the heater lever in the cabin to the flapper box under the car has me flumuxted! How do you connect the wire heater pull cable to the flapper box? anyone have a picture and maybe I can "McGiver" something together....
thx
td
rhodyguy
post Jan 5 2013, 04:18 PM
is the heat control handle pushed down?
tadink   flapper box heater attachment - RESOLVED!   Jan 5 2013, 04:03 PM
rhodyguy   you need a barrel nut on each of the control valve...   Jan 5 2013, 04:10 PM
tadink   you need a barrel nut on each of the control valv...   Jan 5 2013, 04:16 PM
rhodyguy   is the heat control handle pushed down?   Jan 5 2013, 04:18 PM
tadink   is the heat control handle pushed down? Lever ...   Jan 5 2013, 04:22 PM
JawjaPorsche   Did you put in a new cable? The passenger side is...   Jan 5 2013, 04:24 PM
tadink   hmmmm, interesting question - The cable does not l...   Jan 5 2013, 04:29 PM
rhodyguy   no pict of the rest of the ducting. do the warm ai...   Jan 5 2013, 04:30 PM
tadink   no pict of the rest of the ducting. do the warm a...   Jan 5 2013, 04:34 PM
tadink   OK _ I'm going to head out and fuch around wit...   Jan 5 2013, 04:31 PM
mepstein   I would buy a new cable and get some barrel nuts. ...   Jan 5 2013, 04:39 PM
rhodyguy   with the elbow and valve (arm on the bottom) in pl...   Jan 5 2013, 04:41 PM
tadink   HI guys - OK< have the drivers side hooked u...   Jan 5 2013, 05:01 PM
rhodyguy   arms to the bottom. haynes, p.15 fig.3.4. try swit...   Jan 5 2013, 05:27 PM
tadink   Now I'm not one to doubt Haynes - - - uh, but,...   Jan 5 2013, 06:51 PM
reharvey   The arms on all of my cars are on the top. Is this...   Jan 5 2013, 06:53 PM
JawjaPorsche   The arms on all of my cars are on the top. Is thi...   Jan 5 2013, 07:43 PM
BKLA   My '70 had the same issue and the cables look ...   Jan 5 2013, 08:06 PM
Spoke   The cable ends on my car were cut when I bought it...   Jan 6 2013, 07:46 AM
arsprod   The cable ends on my car were cut when I bought i...   Nov 26 2015, 01:55 PM
rgalla9146   The cable ends on my car were cut when I bought ...   Nov 27 2015, 07:56 AM
arsprod   [quote name='arsprod' post='2269961' date='Nov 26...   Nov 27 2015, 08:00 AM
mepstein   You could buy similar wire and find some barrel nu...   Jan 6 2013, 08:20 AM
wndsnd   Porsche Workshop Manual shows arms on top:   Jan 6 2013, 09:48 AM
Dr Evil   You can get barrel nuts at the "Help" se...   Jan 6 2013, 09:57 AM
tadink   THANKS everyone - I'm headed down the hill to ...   Jan 6 2013, 11:40 AM
steuspeed   In my case the passeger side wire was too long bec...   Jan 6 2013, 12:50 PM
Gint   I can't tell from your picture, are your arms ...   Jan 6 2013, 01:13 PM
wndsnd   RE: flapper box heater attachment - RESOLVED!   Jan 6 2013, 01:22 PM
Gint   Good and krusty, but it's all there.   Jan 6 2013, 01:23 PM
wndsnd   Good and krusty, but it's all there. Well ...   Jan 6 2013, 01:33 PM
tadink   YIKES - I thought mine looked bad....sheesh. OK...   Jan 6 2013, 07:01 PM
Gint   Make sure you didn't just pull one cable again...   Jan 6 2013, 08:26 PM
Dave_Darling   The barrel nut should be able to crank down enough...   Nov 26 2015, 08:52 PM
barefoot   The barrel nut should be able to crank down enoug...   Nov 26 2015, 09:10 PM
arsprod   The barrel nut should be able to crank down enou...   Nov 27 2015, 07:21 AM
barefoot   Barrel nuts: http://www.pelicanparts.com/catalog/S...   Nov 27 2015, 08:29 AM
arsprod   I don't usually post pics of my work but this ...   Nov 27 2015, 11:30 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:46 PM
