| tadink |
Jan 5 2013, 04:03 PM
Member ![]() ![]() Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
hi guys -
I'm under the car trying to hook up my heater system - but the wire cable connector from the heater lever in the cabin to the flapper box under the car has me flumuxted! How do you connect the wire heater pull cable to the flapper box? anyone have a picture and maybe I can "McGiver" something together.... thx td |
| tadink |
Jan 6 2013, 07:01 PM
YIKES - I thought mine looked bad....sheesh.
OK< update: I have heat! Napa parts came up with a barrel nut that was of course too large for the porsche part it is supposed to fit into. Given that the weekend is nigh over, and heat remains a priority - I was able to modify the barrel nut to fit the end of the wire, and then gave a mighty tug to ensure it would not slip off - - - - wait for it - - - - and gained about an inch or so in length when something gave way in the tunnel. good grief. However, it remained to find a way to secure / attach the barrel nut to the flapper arm - and with some good old coat hanger ingenuity - we now have heat! I'll do it right when I find the right barrel nuts - but for now we are back on the road! Thanks guys for all your help - I think this myth is busted! cheers td |
tadink flapper box heater attachment - RESOLVED! Jan 5 2013, 04:03 PM
rhodyguy you need a barrel nut on each of the control valve... Jan 5 2013, 04:10 PM
tadink
you need a barrel nut on each of the control valv... Jan 5 2013, 04:16 PM
rhodyguy is the heat control handle pushed down? Jan 5 2013, 04:18 PM
tadink
Lever ... Jan 5 2013, 04:22 PM
JawjaPorsche Did you put in a new cable? The passenger side is... Jan 5 2013, 04:24 PM
tadink hmmmm, interesting question - The cable does not l... Jan 5 2013, 04:29 PM
rhodyguy no pict of the rest of the ducting. do the warm ai... Jan 5 2013, 04:30 PM
tadink
no pict of the rest of the ducting. do the warm a... Jan 5 2013, 04:34 PM
tadink OK _ I'm going to head out and fuch around wit... Jan 5 2013, 04:31 PM
mepstein I would buy a new cable and get some barrel nuts. ... Jan 5 2013, 04:39 PM
rhodyguy with the elbow and valve (arm on the bottom) in pl... Jan 5 2013, 04:41 PM
tadink HI guys -
OK< have the drivers side hooked u... Jan 5 2013, 05:01 PM
rhodyguy arms to the bottom. haynes, p.15 fig.3.4. try swit... Jan 5 2013, 05:27 PM
tadink Now I'm not one to doubt Haynes - - - uh, but,... Jan 5 2013, 06:51 PM
reharvey The arms on all of my cars are on the top. Is this... Jan 5 2013, 06:53 PM
JawjaPorsche
The arms on all of my cars are on the top. Is thi... Jan 5 2013, 07:43 PM
BKLA My '70 had the same issue and the cables look ... Jan 5 2013, 08:06 PM
Spoke The cable ends on my car were cut when I bought it... Jan 6 2013, 07:46 AM
arsprod
The cable ends on my car were cut when I bought i... Nov 26 2015, 01:55 PM
rgalla9146
The cable ends on my car were cut when I bought ... Nov 27 2015, 07:56 AM
arsprod
[quote name='arsprod' post='2269961' date='Nov 26... Nov 27 2015, 08:00 AM
mepstein You could buy similar wire and find some barrel nu... Jan 6 2013, 08:20 AM
wndsnd Porsche Workshop Manual shows arms on top:
Jan 6 2013, 09:48 AM
Dr Evil You can get barrel nuts at the "Help" se... Jan 6 2013, 09:57 AM
tadink THANKS everyone - I'm headed down the hill to ... Jan 6 2013, 11:40 AM
steuspeed In my case the passeger side wire was too long bec... Jan 6 2013, 12:50 PM
Gint I can't tell from your picture, are your arms ... Jan 6 2013, 01:13 PM
wndsnd RE: flapper box heater attachment - RESOLVED! Jan 6 2013, 01:22 PM
Gint Good and krusty, but it's all there. Jan 6 2013, 01:23 PM
wndsnd
Well ... Jan 6 2013, 01:33 PM
Gint Make sure you didn't just pull one cable again... Jan 6 2013, 08:26 PM
Dave_Darling The barrel nut should be able to crank down enough... Nov 26 2015, 08:52 PM
barefoot
The barrel nut should be able to crank down enoug... Nov 26 2015, 09:10 PM
arsprod
The barrel nut should be able to crank down enou... Nov 27 2015, 07:21 AM
barefoot Barrel nuts:
http://www.pelicanparts.com/catalog/S... Nov 27 2015, 08:29 AM
arsprod I don't usually post pics of my work but this ... Nov 27 2015, 11:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:23 PM |
