| ThePaintedMan |
Jan 7 2013, 02:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
I took the advice of a few folks on here and finally got around to buying a quality vacuum gauge. As a primer, I've had all kinds of issues, from carb synching, timing, etc. But I think I've finally got it running fairly well. The car is a '73 with a 1.7, dual Weber 40 IDFs.
Anyhow, I did a compression test the *right* way this time with the throttle open and after the engine was warm and got 110 across the board. Not great, but not awful. Next I moved onto checking the vacuum on each manifold port at the base of the carbs. I get wildly, but consistently fluctuating numbers on each cylinder. By that I mean, at idle, each cylinder displays the same thing - the needle bounces from 5-17 mm Hg instead of a steady number. I've been reading up on this at: http://www.thesamba.com/vw/forum/viewtopic.php?t=476817 and the great animations at: http://www.therangerstation.com/Magazine/S...VacuumLeaks.htm Is it then possible that I have FOUR burned exhaust valves? I had been suspecting I had at least one for awhile, due to seemingly high CHTs on #3, "sucking" coming from the tailpipe and the fact that #3 doesn't suck nearly as much air from the velocity stack as the others. But now I'm suspecting a larger issue. Is it possible that both heads are loose? I see some oil leaking from the cylinder-case junction, but don't see anything from the head-cylinder junction. Would it be worth taking the in off and trying to retorque all the head studs, if nothing else, for piece of mind? -George |
| Mike Bellis |
Jan 7 2013, 04:54 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
You need an "inches of water" vacuum gauge. A regular gauge will not work to sync carbs as well.
ThePaintedMan Callin the Cap'n or other engine Yodas Jan 7 2013, 02:13 PM
brant is this a high duration camshaft?
there can be va... Jan 7 2013, 02:39 PM
Madswede
there can be va... Jan 7 2013, 06:57 PM
wndsrfr You're going to get a bouncing vacuum signal o... Jan 7 2013, 02:51 PM
Dave_Darling The instructions you're following are for a sy... Jan 7 2013, 04:48 PM
rhodyguy george, the bouncy needle at idle is to be expecte... Jan 7 2013, 05:08 PM
ThePaintedMan I feel like all of my posts end up being "doo... Jan 7 2013, 05:35 PM
Elliot Cannon
I feel like all of my posts end up being "do... Jan 7 2013, 07:19 PM
Elliot Cannon This helped me a whole lot. http://carburetion... Jan 7 2013, 07:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:28 PM |
