| Elliot Cannon |
Jan 9 2013, 08:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
While taking things apart for my 5lug conversion, I was taking the stub axle off and found there was NO CV joint gasket between the stub axle and the CV joint. Is this normal or did I just forget to install one when I replaced the axle about 7 years ago. (IMG:style_emoticons/default/wacko.gif) Is there any way to determine what kind of shape the CV joints are in without actually taking all the bearings out? (IMG:style_emoticons/default/idea.gif)
Thanks, Elliot |
| abnrdo |
Jan 9 2013, 08:27 PM
Member ![]() ![]() Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
Mine had Permatex and no gasket.
Elliot Cannon CV joint gaskets. Or not! Jan 9 2013, 08:12 PM
Jeffs9146 This has been an on going debate and I would say i... Jan 9 2013, 08:16 PM
pcar916 I use only high-temperature Permatex with no gaske... Jan 9 2013, 08:59 PM
mrbubblehead This is one job i dread. I don't use gaskets e... Jan 9 2013, 10:54 PM
Andyrew No gaskets on my v8 drifter... No leaks, always dr... Jan 10 2013, 01:24 AM
euro911 I install them and mine don't leak :confused:
... Jan 10 2013, 01:41 AM
bulitt
While taking things apart for my 5lug conversion,... Jan 10 2013, 07:24 AM
pcar916
I would think if the CV's are still packed wi... Jan 10 2013, 09:36 AM
Eric_Shea Elliott,
I'd put the proper gasket in there. ... Jan 10 2013, 09:42 AM
Gint I always use 'em. They're cheap. It... Jan 10 2013, 06:37 PM
Valy Make sure you don't overfill the boots with gr... Jan 11 2013, 04:04 PM
mrbubblehead
Make sure you don't overfill the boots with g... Jan 11 2013, 05:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th October 2026 - 09:37 PM |
