914 air pressure measurements, The results are in! |
bondo |
Jun 22 2004, 10:05 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
With the help of my lovely wife, I have made the air pressure measurements on my 914 at speed. The reference point was the ashtray in the dash. The ends of both hoses were buried in the center of 2" blocks of open cell foam to prevent air movement from affecting the pressure readings. I realize the reference point is not going to be at exactly zero, but as a reference it will show pressure diffrences between different parts of the car. The windows were rolled up, and the targa top was on. Here are the numbers, in kilopascals:
at 45 MPH front center of front bumper: 0.21 middle top of front trunk lid: 0.03 inside front of front wheel well: 0.00 middle top of roll bar: -0.03 middle of rear window: -0.03 inside engine compartment (coasting at idle): -0.01 inside rear wheel well: 0.02 at 65 MPH front center of front bumper: 0.44 middle top of front trunk lid: 0.02 inside front of front wheel well: 0.01 middle top of roll bar: -0.05 middle of rear window: -0.04 inside engine compartment (coasting at idle): -0.03 inside rear wheel well: 0.03 After our last measurement, we rolled down the driver's side window and drove at 45 MPH to see what difference that made on the reference point. The rear wheel well measurement went up from 0.02 to 0.07, which means that at 45 MPH the pressure at the ashtray is 0.05 kPa lower with the driver's side window down. Whelp, there's my little numerical contribution to the 914 community. --Royce |
lmcchesney |
Jun 23 2004, 07:32 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
What is the conversion/relation between kilopascals and mmHg or PSI or Atms.?
The impeller can generate a neg. pressure, but that also limits the flow. Where in the engine compartment was the sensor? The rear roll bar and window has a neg. pressure enviroment as well. Thus, opening the engine lid to the GT style would open the impeller to a greater neg. pressure enviroment. That would suggest the need for a positive pressure cold air intake. Deserves a classic post status. L. McC |
Lo-Fi Version | Time is now: 15th June 2024 - 10:39 PM |
