| Erben914 |
Jan 13 2013, 02:52 PM
Member ![]() ![]() Group: Members Posts: 137 Joined: 1-January 13 From: Sacramento Member No.: 15,314 Region Association: Central California |
Hey guys I need some advice. My engine bar is bent backwards towards the rear of the car. The bar itself looks fine, but the two bolts are angled about 60 degrees instead of 90. My shift linkage is rubbing but isn't causing any problems.
My question is... Should I use a big pry bar and bent it back to vertical or do I need to drop the bar and do something at the mount area? I don't want to weaken the bolts or the mounts more. Are the mounts rubber and they just need to be re seated? Thanks for any help |
| McMark |
Jan 14 2013, 12:13 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Best way to completely remedy this issue:
1. support the engine with a jack stand. 2. Remove the engine bar completely. 3. Remove the rubber engine mounts and visually inspect the rubber as well as the steel brackets bolted to the engine case. Replace as necessary. 4. remove the outer brackets from the body and straighten with a large punch (drift actually) and sledge hammer. 5. visually inspect the bar itself for bent ends. The bar can actually be bent/twisted pretty easily. A large vice securely mounted to a bench and a crescent wrench should be all that's necessary to straighten. 6. Reinstall all straightened pieces, don't torque/tighten anything until all bolts are in place to eliminate pre-loading. |
Erben914 Engine bar mounts are bent backwards Jan 13 2013, 02:52 PM
brant you drug over a parking curb / trailer / or someth... Jan 13 2013, 02:57 PM
Erben914
you drug over a parking curb / trailer / or somet... Jan 13 2013, 03:21 PM
brant just be careful if you pry against anything.
the ... Jan 13 2013, 03:22 PM
sixnotfour speed bump backwards should do it.. Jan 13 2013, 03:25 PM
rgalla9146
Tail shift... Jan 13 2013, 04:38 PM
draganc
LMFAO. :ro... Jan 14 2013, 07:25 PM
reharvey The brackets the bolts go though may also be bent. Jan 13 2013, 04:09 PM
stugray We need to know what year.
The motor mounts are di... Jan 13 2013, 04:28 PM
last337 I have the exact same problem and have been thinki... Jan 13 2013, 04:45 PM
reharvey
I have the exact same problem and have been think... Jan 13 2013, 06:06 PM
Spoke I recently had to remove the engine bar to do some... Jan 13 2013, 06:54 PM
last337
I recently had to remove the engine bar to do som... Jan 13 2013, 07:00 PM
last337
ottox914 Better pics would help. Sounds like you are on th... Jan 13 2013, 07:23 PM
Dave_Darling The big bolts are already eff'ed, so go ahead ... Jan 13 2013, 09:35 PM
Valy I have a good engine bar for you for free. Just co... Jan 13 2013, 10:31 PM
euro911 It would take a lot to bend a cast iron engine bar... Jan 14 2013, 12:35 PM
last337
It would take a lot to bend a cast iron engine ba... Jan 14 2013, 12:58 PM
JawjaPorsche
It would take a lot to bend a cast iron engine b... Jan 14 2013, 01:15 PM
last337 I have a '73 2.0 so I guess that means it is a... Jan 14 2013, 01:19 PM
JawjaPorsche
I have a '73 2.0 so I guess that means it is ... Jan 14 2013, 01:22 PM
last337
I have a '73 2.0 so I guess that means it is... Jan 14 2013, 02:15 PM
euro911 I have a '73 2.0 so I guess that means it is a... Jan 14 2013, 07:18 PM
last337
I have a '73 2.0 so I guess that means it is ... Jan 14 2013, 07:29 PM
McMark
That's what I thought. But I had one that wa... Jan 14 2013, 05:26 PM
The Cabinetmaker I've seen this on lots of cars. It's almos... Jan 14 2013, 05:27 PM
last337 Well upon closer inspection it appears To be the e... Jan 14 2013, 07:24 PM
euro911 RE: Engine bar mounts are bent backwards Jan 14 2013, 10:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 08:47 AM |
