914-6 Long Repair -Am I nuts to tackle it myself?, Any Minnesotans with firsthand experience? |
vintage914racer |
Jan 25 2013, 09:25 PM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
I always knew my factory 914-6 had rust lurking under the rockers, but I didn't want to investigate for fear finding something bad. Last winter I bit the bullet and pulled the outer rockers. As is likely customary, I found a bunch of moist debris that had accumulated around each respective jack point. After close inspection with a screwdriver it appears that only the outer sheet metal needs attention. I know this thread is worthless without pictures, but humor me... There is an area measuring roughly 8" x 4" directly surrounding the passenger side jack post that needs replacing. Am I nuts to try to tackle this myself? I've done some welding and have a welder, so I am not averse to doing it.
If the collective experts think I should tackle it I have a couple of follow up quesitons. I assume I should pull the engine and trans to do this? Is there anyone in the Minneapolis area with the support bars that span the door area? |
rick 918-S |
Jan 26 2013, 07:35 PM
Hey nice rack! -Celette Group: Members Posts: 20,489 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
That's way more than a parch. Have Paul take a look at it. His car is top notch. It can be repaired without setting it up on a bench. Lots of guys have done it. But if your a novice welder you may not want to fudge up your factory 6. Do it right and protect the value.
Lo-Fi Version | Time is now: 7th June 2024 - 02:32 PM |
