| pbob42 |
Feb 9 2013, 01:45 PM
Newbie ![]() Group: Members Posts: 46 Joined: 6-June 12 From: san diego Member No.: 14,531 Region Association: None |
Replacing the firewall and shiftrod bushings. PO stripped out the set screws 20 years ago and left the project undone. I am drilling out the set screws but the linkage is locked together at both set screw locations (rear and firewall).
Any suggestions on getting this linkage apart? |
| timothy_nd28 |
Feb 9 2013, 02:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
(IMG:style_emoticons/default/sawzall-smiley.gif) and post a WTB ad in the classified section
pbob42 Re-bushing my side shifter, drilling etc. Feb 9 2013, 01:45 PM
wildman you might try shifting into a forward gear (like 2... Feb 9 2013, 02:45 PM
pbob42
you might try shifting into a forward gear (like ... Feb 9 2013, 05:51 PM
brant a bigger drill bit
I've had to do it one
I to... Feb 9 2013, 05:59 PM
rhodyguy try going thru the access cover (center tunnel, un... Feb 9 2013, 06:08 PM
flash914 Left hand drill bits PB blaster and heat. Feb 9 2013, 06:54 PM
rhodyguy the set screws have a nub on the end that go into ... Feb 9 2013, 07:05 PM
euro911 I would try penetrating oil and an easy-out first.... Feb 9 2013, 09:59 PM
pbob42 Got off track - had to put a starter in my daughte... Feb 12 2013, 11:05 AM
worn
Got off track - had to put a starter in my daught... Feb 12 2013, 11:30 AM
pbob42 I've been working at the back. I will see if ... Feb 12 2013, 12:08 PM
rhodyguy if you think the set screw situation is hopeless, ... Feb 12 2013, 12:14 PM
pbob42 first fire then hacksaw. Got it. Feb 12 2013, 12:20 PM
euro911 If the PO used RED lock-tite, it's gonna be t... Feb 12 2013, 01:00 PM
rhodyguy what's a hacksaw? :D power tools. Feb 12 2013, 01:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 01:34 PM |
