| Series9 |
Feb 9 2013, 10:15 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I build 10.5:1 /6 engines pretty regularly. 93 octane and single plug. That's about the limit without going twin-plug, but all of them on the road have been fine.
Why don't I see this in Type 1 or Type 4 engines? Some rough math suggests a 2.0 @ 8.5:1 is an 85hp engine, while the same engine at 10.5:1 would give almost 120hp. Just thinking out loud..... (IMG:style_emoticons/default/beerchug.gif) |
| Dasnowman |
Feb 10 2013, 01:49 AM
You miss 100% of shots you don't take! ![]() ![]() Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
What about doing a modern efi system with aquamist injection of 50/50 mix of water/methenal.. Still would need some big cams and nice flowing heads.. |
Series9 Anybody Built a 10.5:1 Type 1 or 4 Engine? Feb 9 2013, 10:15 PM
Valy It's all about the cam you use. Longer duratio... Feb 9 2013, 10:36 PM
euro911 Case design/strength? :confused:
Running a 9:1 C... Feb 9 2013, 10:37 PM
larryM where ya planning to buy gas for it?
i paid ... Feb 9 2013, 10:41 PM
messix i think it's more a question of what heads you... Feb 10 2013, 12:29 AM
rick 918-S No short answer Joe. Here's my short answer. 1... Feb 10 2013, 12:31 AM
Dave_Darling The 911 has a better combustion chamber and better... Feb 10 2013, 12:37 AM
a914622 If you real want the 12-1 comp. motor to run you n... Feb 10 2013, 01:05 AM
Series9
I had a 12-1 type1 1300 that broke 2 trannys on... Feb 10 2013, 08:44 AM
Racer Chris I had a 10.5:1 engine in my street 914 for a coupl... Feb 10 2013, 09:39 AM
Tom_T
I build 10.5:1 /6 engines pretty regularly. 93 o... Feb 10 2013, 02:20 PM
euro911 When I mentioned the case, I should have elaborate... Feb 10 2013, 03:52 PM
Mark Henry On the other end of the scale the 2007cc Gene Berg... Feb 10 2013, 11:02 PM
r_towle
On the other end of the scale the 2007cc Gene Ber... Feb 11 2013, 02:37 PM
Bleyseng a 2056 with 9 to 1CR with the right cam and valves... Feb 11 2013, 01:14 PM
r_towle
I build 10.5:1 /6 engines pretty regularly. 93 o... Feb 11 2013, 02:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th August 2026 - 12:17 AM |
