> MPG change, where to start looking?
914Bryan
post Feb 10 2013, 08:23 AM
I know this isn't an exciting high performance question, but a question just the same.
I'm having an issue with the mileage my 74 2.0 DJet and am wondering where to start looking for the problem. I commute 60 miles each way to work (120 total). My driving is 98% freeway, non rush hours so a steady 75 mph, motor is turning 3200.
I could always count on 32mpg, day in, day out. Over the last two months, it has slipped to 28mpg. I burn a tank a week, so this has been about 8 tanks of gas that I have noticed this.
Engine is running fine, no change in performance.
Would a tardy valve adjustment cause this? I'm a little over 6k since my last one.
Any ideas?
rick 918-S
post Feb 10 2013, 10:39 AM
Hey nice rack! -Celette
Fast check for the points is ignition timing will change. Smaller gap will have less of an effect on mileage as it will increase the time to coil builds energy. (which is actually a benefit) The change is in efficiency will be in the timing change by the shift in dwell angle.
914Bryan   MPG change, where to start looking?   Feb 10 2013, 08:23 AM
jonvo4591   I was in an autotive training class last week and ...   Feb 10 2013, 08:43 AM
JamesM   I was in an autotive training class last week and...   Feb 10 2013, 10:20 AM
somd914   Have you noticed any other issues with the engine?...   Feb 10 2013, 09:31 AM
rick 918-S   Fuel was my thought also. There is no good reason ...   Feb 10 2013, 09:37 AM
tscrihfield   Fuel was my thought also. There is no good reason...   Feb 10 2013, 09:54 AM
3d914   Ditto on the points. And when you check them, don...   Feb 10 2013, 10:04 AM
Cupomeat   With everyone else's advice, I'd go over t...   Feb 10 2013, 10:22 AM
Vacca Rabite   Now, strangely my audi 1.8t motor seems to give ...   Feb 10 2013, 10:33 AM
Cupomeat   Now, strangely my audi 1.8t motor seems to give...   Feb 10 2013, 10:34 AM
6freak   Now, strangely my audi 1.8t motor seems to give...   Feb 11 2013, 11:16 AM
rick 918-S   Fast check for the points is ignition timing will ...   Feb 10 2013, 10:39 AM
Tom_T   I know this isn't an exciting high performanc...   Feb 10 2013, 01:33 PM
Dave_Darling   It is normal for your fuel economy to suffer when ...   Feb 10 2013, 02:53 PM
bulitt   Rear brakes dragging?   Feb 10 2013, 03:06 PM
bandjoey   IS THERE A WAY to test the gasoline to see the alc...   Feb 10 2013, 07:53 PM
Vacca Rabite   sure. run to flaps and get some test kits. they ...   Feb 10 2013, 08:03 PM
914Bryan   Thanks everyone, this is all great advice! Mos...   Feb 10 2013, 08:09 PM
euro911   Having the same issue with my Toyota trucks. Been ...   Feb 10 2013, 08:21 PM
Katmanken   Winter gas mix has more aromatic volatiles in the ...   Feb 10 2013, 08:52 PM
jonvo4591   To do a down and drity alcohol content test, you...   Feb 10 2013, 09:34 PM
r_towle   our Prius gets almost 60mpg in the summer. In the ...   Feb 11 2013, 10:23 AM
- Lo-Fi Version Time is now: 17th July 2025 - 01:46 AM
