> What rocker arm ratios do people see?
stugray
post Dec 17 2012, 10:26 PM
I am adjusting the valve geometry while putting in a Raby 9700 cam and I am seeing .38 on the exhaust cam lift and .496 at the valve (an exh rocker ratio of 1.3) and I have a .39 on the intake with a .546 at the valve ( an int rocker ratio of 1.4) is this what everyone else gets for rocker ratios:
Intake rocker ratio = 1.4
Exhaust rocker ratio = 1.3
These are the 1.7 (1.8?) rockers that accept the 911 swivel feet.
I am using the swivel feet, have modified the rocker faces, adjustable push rod, and zero lash to do the meaurements.
Do those rocker ratios look like stock?
I want to take 50 thousandths off the Combustion chambers to increase the CR, but my measurements say I wont have enough clearance on the Intake valve once I shave off 50 thousandths.
I only have ~0.075 clearance now from the piston to the Int valve as it is with a deck of 0.030 and everything else (crank & rods) stock - flat top 96mm pistons.
That Intake valve travel of ~0.55 looks huge to me. Anyone else care to comment?
Stu
ChrisFoley
post Feb 10 2013, 11:05 PM
I am Tangerine Racing
It is not possible that you are the first to discover the rocker ratio is different than what everyone has believed for 40 years.
There is only one remaining possibility - the camshaft is fubar.
stugray   What rocker arm ratios do people see?   Dec 17 2012, 10:26 PM
Dave_Darling   The stock ratios range from 1.3 to 1.4, so you...   Dec 17 2012, 11:29 PM
edwin   Call European machine works? They've helped in...   Dec 17 2012, 11:38 PM
stugray   Dave - So is it possible to find an intake rocker ...   Dec 18 2012, 12:08 PM
Dave_Darling   Dave - So is it possible to find an intake rocker...   Dec 18 2012, 06:02 PM
monkeyboy   I believe WebCam actually makes them, but they are...   Dec 18 2012, 12:32 PM
brant   I too believe they are built to order... custom o...   Dec 18 2012, 12:41 PM
Mark Henry   I too believe they are built to order... custom ...   Dec 18 2012, 12:45 PM
bobhasissues   When you say "at the valve" are you actu...   Dec 18 2012, 06:23 PM
stugray   bob - Yes - and simultaneously at the pushrod t...   Dec 18 2012, 07:22 PM
bobhasissues   Stu, Nobody will try to help you if you continue ...   Dec 18 2012, 09:40 PM
stugray   Stu, Nobody will try to help you if you continue...   Feb 10 2013, 11:07 PM
bobhasissues   Bob, now that we have established that these rocke...   Feb 11 2013, 08:15 PM
stugray   bob- I see nowhere in the previous post that co...   Dec 18 2012, 11:01 PM
Racer Chris   I'll gladly trade you a set of 1.3 ratio, 1.7L...   Dec 18 2012, 11:44 PM
Mark Henry   Dude the reason I don't help you is simple.......   Dec 18 2012, 11:50 PM
stugray   That's funny because it says Type IV store r...   Dec 19 2012, 08:27 AM
Racer Chris   I am also reading on Jakes cam instructions that ...   Dec 19 2012, 10:10 AM
Jeff Hail   I am also reading on Jakes cam instructions that...   Feb 4 2015, 11:39 PM
Mark Henry   [quote name='Racer Chris' post='1786713' date='De...   Feb 5 2015, 06:27 AM
r_towle   post a picture of the cam card. It will possibly g...   Dec 19 2012, 09:13 AM
stugray   rich, Thanks. I will scan the card & post it ...   Dec 19 2012, 09:33 AM
stugray   I will take pictures tonight. I measure .388 Cam...   Dec 19 2012, 11:42 AM
nathansnathan   "Valve lift" is taking the ratio of the ...   Dec 19 2012, 11:50 AM
stugray   I will get pics of the test rig after dinner, but ...   Dec 19 2012, 07:04 PM
Todd Enlund   And BTW - I fully profiled the cam myself, and th...   Dec 27 2012, 02:22 AM
Racer Chris   And BTW - I fully profiled the cam myself, and t...   Dec 27 2012, 05:55 AM
r_towle   I am confused. You have not milled out your heads ...   Dec 19 2012, 07:41 PM
stugray   Not exactly - I am measuring how much clearance ...   Dec 19 2012, 08:43 PM
stugray   Some pics: Pics of setup to measure deck height: ...   Dec 19 2012, 09:02 PM
nathansnathan   My experience with it was that it was easy to get ...   Dec 19 2012, 11:42 PM
stugray   I have taken ~.060 off the rocker faces and coun...   Dec 20 2012, 12:02 AM
nathansnathan   I have taken ~.060 off the rocker faces and cou...   Dec 20 2012, 08:36 AM
Racer Chris   Stu, Is it possible the ratio was altered by remac...   Dec 20 2012, 10:02 AM
stugray   Racer Chris, I measured all 4 of them, Valve lift...   Dec 22 2012, 04:09 PM
stugray   Ok, so after some measurements, I get the whole ...   Dec 23 2012, 06:29 PM
stugray   Two more questions: 1 - When some of you have had...   Dec 24 2012, 04:51 PM
nathansnathan   And nathansnathan How is that possible? Regard...   Dec 30 2012, 06:02 PM
wndsrfr   2 - Who has a good selection of rocker shims? ...   Dec 30 2012, 07:26 PM
stugray   Quick bump so racer chris doesnt forget about me ;...   Dec 26 2012, 05:17 PM
Racer Chris   Quick bump so racer chris doesnt forget about me ...   Dec 26 2012, 07:10 PM
tscrihfield   stu, if i could lend some advice. I would not adv...   Dec 26 2012, 07:17 PM
nathansnathan   I've given it more thought their and edited ab...   Dec 30 2012, 10:02 PM
stugray   So I had the engine case "decked", the r...   Feb 10 2013, 05:11 PM
nathansnathan   It sounds to me like you are doing something wrong...   Feb 10 2013, 06:44 PM
stugray   :confused:   Feb 10 2013, 10:54 PM
Racer Chris   It is not possible that you are the first to disco...   Feb 10 2013, 11:05 PM
stugray   Chris - I had three reputable machine heads sit ...   Feb 10 2013, 11:13 PM
barefoot   Chris - I had three reputable machine heads sit...   Dec 7 2015, 04:34 PM
stugray   Chris - I had three reputable machine heads si...   Dec 7 2015, 07:31 PM
barefoot   [quote name='stugray' post='1818427...   Dec 7 2015, 08:50 PM
Racer Chris   The cam card says the valve lift is .368". Yo...   Feb 11 2013, 12:03 AM
stugray   Chris, That's right. I need to remeasure the ...   Feb 11 2013, 07:51 AM
worn   Chris, That's right. I need to remeasure the...   Feb 11 2013, 10:30 AM
stugray   I just spoke with one of the Type-IV experts at Fa...   Feb 11 2013, 02:11 PM
stugray   Bob I " will build a grenade, that's why ...   Feb 12 2013, 02:40 PM
stugray   Ok, so I decided to go with a webcam 86b instead o...   Mar 26 2013, 08:25 PM
worn   Ok, so I decided to go with a webcam 86b instead ...   Mar 27 2013, 09:38 AM
nathansnathan   So apparently Webcam knows that these rockers are...   Mar 27 2013, 11:09 AM
stugray   My plan is to set the intake right at the "ad...   Mar 27 2013, 12:13 PM
worn   My plan is to set the intake right at the "a...   Mar 27 2013, 02:09 PM
stugray   I have found (after testing 8 sets of rockers) tha...   Mar 27 2013, 03:29 PM
stugray   So I put in the new webcam 86b. Advertised lift i...   Mar 31 2013, 03:14 PM
stugray   Just finished the "Clay on the Piston" t...   Mar 31 2013, 03:26 PM
stugray   One observation that I made: When measuring the w...   Apr 1 2013, 09:55 AM
stugray   Important lesson learned! I cut the pushrods ...   Apr 3 2013, 12:20 PM
worn   Important lesson learned! I cut the pushrods...   Apr 3 2013, 03:22 PM
Jake Raby   So much for us just repackaging things and selli...   Apr 3 2013, 06:43 PM
worn   Not even Web Cam knows what we do to camshafts...   Apr 4 2013, 10:35 AM
stugray   Jake I have promoted your hardware often, even a...   Apr 3 2013, 09:39 PM
Jake Raby   Jake I have promoted your hardware often, even ...   Apr 4 2013, 05:45 PM
stugray   Jake, the above quote was merely an exact comment ...   Apr 4 2013, 09:21 PM
stugray   After going through all of this measuring and havi...   Apr 29 2013, 01:31 PM
stugray   Bump the above question for rdauenhauer. Jake? Ty...   Feb 4 2015, 02:21 PM
rdauenhauer   I missed this. Good read.   Feb 4 2015, 03:19 PM
Dave_Darling   The ratio of all of the stock rockers "should...   Dec 7 2015, 05:30 PM
Steve Pratel   :rotfl: Really? come on guys let it go already.   Dec 7 2015, 08:54 PM
stugray   :rotfl: Really? come on guys let it go already. ...   Dec 7 2015, 09:43 PM
Superhawk996   :rotfl: Really? come on guys let it go already. ...   Jan 9 2022, 08:18 AM
930cabman   What is the consensus from this dramatic post? can...   Jan 8 2022, 06:14 PM
iankarr   I used Jake's method as the basis for my video...   Jan 9 2022, 09:52 AM
930cabman   I used Jake's method as the basis for my vide...   Jan 9 2022, 10:34 AM
iankarr   Please don’t do THAT lol. Jake’s method, yesâ€...   Jan 9 2022, 10:43 AM
Mark Henry   There's always going to be variants of small d...   Jan 9 2022, 11:50 AM
930cabman   Exactly, overthinking can be problematic. Part of ...   Jan 9 2022, 04:01 PM
- Lo-Fi Version Time is now: 19th October 2026 - 01:20 AM
