> Batteries, Batteries, Batteries, What do you use or recommend in a 914? Original Porsche Battery & Fuel Rail Recall Info
tumamilhem
post Feb 11 2013, 12:56 PM
LUFTBRIGADE
I know there have been a couple threads mentioning this, but I thought it would be helpful to have a thread solitary to the discussion of batteries to compare and contrast the pros and cons of many options to make an educated and sound decision when buying the right kind of battery for your car. This will also serve as a good guide by seasoned owners for new 914 owners.
So I'll go first with the most obvious question, and actually a current one, as I am shopping around for a new battery for my car.
What (in your opinion) is the best battery to use in a 914 and why? This is a question I am curious about because I need a new battery.
Many 914 owners prefer the Optima due to its closed top to prevent leaking of acid that drains down into the notorious hell hole, eventually destroying the frame of the car if not tended to. This is a huge advantage. Typically, the type of Optima used is the Red Top / Size 34 Series.
I have used Interstate in the past. I don't find they last too long. I also had cranking issues sometimes. The battery would seam to wear down quicker if I needed to start it a few times.
I am currently trying to take advantage of the recall on the 914 which was the battery issue. I discovered that not only did Porsche provide the battery cover, but replaced fuel lines. I contacted Brumos Porsche (I live locally) inquiring if this was still done. Not only could they not bring up anything via my year and VIN number, but not the recall number either. So they had to make a few phone calls to dig deeper into their archives. It's been a week now and nothing yet.
Here is that recall information for your information:
Porsche 914 Fuel Rail Recalls
Recall Number: 77V105000
Owner Notification Date: July 12, 1977
Record Creation Date: October 12, 1979
Defect Description:
The Battery covers on the involved vehicles may be missing, damaged, or improperly installed. This condition could allow water to contact the top of the battery and mix with acid. This mixture could cause the fuel hoses to deteriorate and lead to fuel leakage.
Defect Consequence: n/a
Corrective Action: Dealer will install a new Battery cover and hold down clamp, and replace all fuel hoses in the engine compartment, without charge to owner.
So what battery do you recommend?
Rand
post Feb 13 2013, 03:40 PM
Cross Member
Now with this new-found preference for Odyssey
Not necessarily! None of this is new-found. You are just new about discovering it. Curious if you have searched this topic before here?
There are a thousand pages already documented on this subject over several years. I appreciate you trying to pull it all together in one thread, but it doesn't work that way. Do some serious research here before you think you are doing something new.
Bottom line: Lead acid batteries are old school. If you have to add water to it, then get rid of it. There are multiple choices for new school batteries. They aren't hard to find.
tumamilhem
post Feb 13 2013, 03:43 PM
LUFTBRIGADE
QUOTE(Rand @ Feb 13 2013, 04:40 PM) *
Yeah, I did look back and search but a LOT of things come up with the word 'battery' in it, very non-related to this discussion though. And not much detail or questions answered that I and what I think others may want to ask. So I thought a one-stop Battery specific topic would be helpful. (IMG:style_emoticons/default/beerchug.gif)
tumamilhem   Batteries, Batteries, Batteries   Feb 11 2013, 12:56 PM
914Eric   Typically, the type of Optima used is the Red Top...   Feb 11 2013, 01:07 PM
tumamilhem   Typically, the type of Optima used is the Red To...   Feb 11 2013, 01:11 PM
tod914   I believe once a year Optima offers a coupon for ...   Feb 11 2013, 01:22 PM
Tom_T   Tuma, Recalls - For the recall you'll need ...   Feb 11 2013, 01:47 PM
tumamilhem   Tuma, Recalls - For the recall you'll need...   Feb 11 2013, 06:55 PM
Tom_T   Tommy - HO only covers the rubber fuel hoses ins...   Feb 12 2013, 10:55 AM
tumamilhem   Tommy - HO only covers the rubber fuel hoses in...   Feb 13 2013, 04:24 PM
Eric_Shea   I do appreciate that information. Very much. I t...   Feb 13 2013, 04:49 PM
MDG   You boys are killing helpless ROMs and RAMs and A...   Feb 13 2013, 04:51 PM
Rand   If we just keep quoting these gigantic posts, pr...   Feb 13 2013, 04:55 PM
MDG   If you don't know how to buy a sealed batter...   Feb 13 2013, 05:05 PM
scotty b   My computer actually . . slows . . down . . . whe...   Feb 13 2013, 07:00 PM
bigkensteele   I like turtles I thought you were into unicorns ...   Feb 13 2013, 08:46 PM
Eric_Shea   I thought you were into unicorns :confused: No...   Feb 13 2013, 08:49 PM
bigkensteele   No... He's turtles. I'm (I guess) unicor...   Feb 13 2013, 08:56 PM
tumamilhem   That's some great info, Tom! Good name too...   Feb 11 2013, 01:55 PM
tod914   You just need to keep checking their website. May...   Feb 11 2013, 05:33 PM
rfuerst911sc   I recently replaced the yellow top Optima in my 75...   Feb 11 2013, 06:02 PM
tumamilhem   Yes, the Red Top batteries are supposedly better s...   Feb 11 2013, 06:50 PM
Rusty   I have used Optima Red Tops with great success. H...   Feb 11 2013, 07:10 PM
tumamilhem   I have used Optima Red Tops with great success. ...   Feb 11 2013, 07:52 PM
Jeff Bowlsby   All of the detailed 914 recall info can be found h...   Feb 11 2013, 08:50 PM
poorsche914   Slight hijack... PS - An interesting data point in...   Feb 11 2013, 09:42 PM
Jeff Bowlsby   Slight hijack... [quote name='Jeff Bowlsby' post=...   Feb 11 2013, 09:45 PM
914Eric   Slight hijack... [quote name='Jeff Bowlsby' post...   Feb 13 2013, 03:17 PM
euro911   ...WHERE did you find that? Source...? That must...   Feb 14 2013, 12:10 AM
tumamilhem   Hey Jeff, I noticed there are TWO different factor...   Feb 11 2013, 09:18 PM
GeorgeRud   The top photo was the one supplied in the recall k...   Feb 11 2013, 09:37 PM
Jeff Bowlsby   Dunno what HO, or what any of the other recall des...   Feb 11 2013, 09:51 PM
doorknobcollector   Just my .02 on batteries--I have had really good l...   Feb 11 2013, 11:28 PM
Tom_T   My oldest one is now 6+ years old, still going st...   Feb 12 2013, 10:31 AM
Chris H.   I have a red top that was purchased in 2004 and it...   Feb 12 2013, 10:57 AM
rfuerst911sc   Just to clarify my two yellow tops were kept on a ...   Feb 12 2013, 05:27 PM
doorknobcollector   When I purchased mine there were two 34's. ...   Feb 12 2013, 07:20 PM
plays with cars   I've become a fan of the Odyssey batteries. I...   Feb 12 2013, 11:44 PM
Rand   I've become a fan of the Odyssey batteries. I...   Feb 13 2013, 12:23 AM
mskala   I'm also running an Odyssey PC680 and love it...   Feb 13 2013, 10:54 AM
mskala   I'm also running an Odyssey PC680 and love it...   Feb 13 2013, 10:56 AM
tumamilhem   Which Odyssey do you guys recommend? Any prefere...   Feb 13 2013, 02:31 PM
Rand   Which Odyssey do you guys recommend? .....Why? Y...   Feb 13 2013, 02:34 PM
balljoint   Which Odyssey do you guys recommend? Any prefer...   Feb 13 2013, 03:33 PM
tumamilhem   Which Odyssey do you guys recommend? Any prefe...   Feb 13 2013, 03:40 PM
tumamilhem   I saw it was a Odyssey PC680. But I'm not fami...   Feb 13 2013, 03:04 PM
Rand   Sorry if this is a tangent, but I think it is rele...   Feb 13 2013, 03:33 PM
tumamilhem   Sorry if this is a tangent, but I think it is rel...   Feb 13 2013, 03:35 PM
Tom_T   Sorry if this is a tangent, but I think it is rel...   Feb 13 2013, 07:26 PM
Rand   Not necessarily! None of this is new-found. Y...   Feb 13 2013, 03:40 PM
tumamilhem   Not necessarily! None of this is new-found. ...   Feb 13 2013, 03:43 PM
Rand   Oof. Eric likes a pink top. Jokes on everyone now....   Feb 13 2013, 03:45 PM
Rand   If I was a genius I would advise you to always req...   Feb 13 2013, 05:11 PM
MDG   If I was a genius I would advise you to always re...   Feb 13 2013, 05:15 PM
Rand   If I was a genius I would advise you to always r...   Feb 13 2013, 05:19 PM
Tom_T   Peanut gallery id's aside.... <_< Tomm...   Feb 13 2013, 07:07 PM
sixnotfour   Lock This Thread...Already   Feb 13 2013, 08:57 PM
Rand   Thanks Tom, for trying to answer my question. Oof...   Feb 13 2013, 09:04 PM
Tom_T   Thanks Tom, for trying to answer my question. Oo...   Feb 13 2013, 09:37 PM
tumamilhem   Thanks Tom, for trying to answer my question. O...   Feb 24 2013, 11:44 PM
balljoint   Sometimes it takes a doofus to post in and point o...   Feb 13 2013, 09:50 PM
Rand   thinking it's enough   Feb 13 2013, 09:53 PM
john_g   The local Walmart has two models of Optima Redtops...   Feb 23 2013, 11:11 PM
rfuerst911sc   I could not find a Odyssey battery locally and was...   Feb 24 2013, 07:03 AM
tumamilhem   So what are the performance differences; pros and ...   Feb 25 2013, 07:22 AM
Tom_T   So what are the performance differences; pros and...   Feb 25 2013, 03:36 PM
tumamilhem   So what are the performance differences; pros an...   Feb 26 2013, 10:45 AM
Rusty   Lock This Thread...Already Tempting... but there...   Feb 25 2013, 05:35 AM
scotty b   [quote name='sixnotfour' post='1819965' date='Feb...   Feb 25 2013, 07:07 AM
Rusty   :agree: Thank you. I do believe that was the ...   Feb 25 2013, 07:09 AM
euro911   I'd put my money on the Odessy ... Optimas are...   Feb 25 2013, 09:56 AM
bigkensteele   I went with the Optima 35. It has been a couple o...   Feb 25 2013, 06:12 PM
Tom_T   Tommy - Someone above listed which Odessy for the...   Feb 26 2013, 11:01 AM
- Lo-Fi Version Time is now: 20th September 2026 - 08:47 AM
