> Looking for a weber rebuilding/cleaning service
casey944
post Feb 20 2013, 04:01 PM
Afternoon!
My 914 has a 1.7L engine(original) and I am running a pair of 36IDF carbs. I have rebuilt them personally, had another relatively local 914 specialist rebuild them and I am still not entirely happy with the way they perform....
Transition and coming on to throttle up to when the main jets come on seems to be the issue.
Is there a rebuilder/cleaner that everyone on here recommends? I figure some sort of ultra sonic blasting to clean out the ports/chambers that I am not able to get to would be the best.
Any insight?
Possibly also rejetting suggestions might be good as well.
Thanks,
Casey
ConeDodger
post Feb 21 2013, 09:43 AM
Apex killer!
You're sure that it is the carbs? Two people, yourself included have rebuilt them and you're sure the jetting is right and there is still a problem? You don't have a vacuum leak at the bases or a balance problem?
Rule out another problem before you spend bigger money on the same solution.
ThePaintedMan
post Feb 21 2013, 09:52 AM
QUOTE(ConeDodger @ Feb 21 2013, 10:43 AM) *
(IMG:style_emoticons/default/agree.gif) With Rob and Kevin. As I sent you in the PM, you probably want to blame the carbs last at this point. It often is them, but it could very well be something simpler and cheaper. I.e. adjust the valves, verify timing and ditch the crappy 009 distributor if thats whats you're using. Also, ensure you have a quality fuel pump and regulator and adequate (3.5 PSI) fuel pressure.
THEN you can fuch with the carbs. After you follow Kev's advice and read Tomlinson's stuff, of couse (IMG:style_emoticons/default/smile.gif)
Welcome to the madness my friend.
casey944   Looking for a weber rebuilding/cleaning service   Feb 20 2013, 04:01 PM
'73-914kid   Did the car drive alright before? Sounds more like...   Feb 20 2013, 04:15 PM
casey944   Did the car drive alright before? Sounds more lik...   Feb 20 2013, 04:27 PM
quadracerx   I have heard that this guy is the guru but have no...   Feb 20 2013, 04:44 PM
jasons   I sent my Dellortos to Air Cooled Engineering. Th...   Feb 20 2013, 05:42 PM
maxwelj   You should take a look at performance oriented. P...   Feb 20 2013, 07:04 PM
Eric_Shea   Paul's the master but is backed up a ways. Ai...   Feb 20 2013, 07:17 PM
Jake Raby   Art at Aircooled Engineering has been prepping car...   Feb 20 2013, 07:26 PM
ThePaintedMan   Afternoon! My 914 has a 1.7L engine(original...   Feb 20 2013, 10:13 PM
DBCooper   Every metropolitan area should have somebody who c...   Feb 21 2013, 07:16 AM
casey944   Thanks all for your input. I have been through th...   Feb 21 2013, 07:58 AM
rhodyguy   i don't think you're fully on the main jet...   Feb 21 2013, 09:31 AM
ConeDodger   You're sure that it is the carbs? Two people, ...   Feb 21 2013, 09:43 AM
ThePaintedMan   You're sure that it is the carbs? Two people,...   Feb 21 2013, 09:52 AM
rhodyguy   adequate fuel delivery and 3.5# MAX.   Feb 21 2013, 10:02 AM
DBCooper   A hundred bucks? Dude! [url=http://www.cbper...   Feb 21 2013, 10:07 AM
ConeDodger   Unfortunately, everything else must be spot-on bef...   Feb 21 2013, 10:37 AM
casey944   The only issue is really throttle response... On t...   Feb 21 2013, 11:14 AM
Eric_Shea   They have a "total douche" $20.00...   Feb 21 2013, 11:22 AM
ThePaintedMan   They have a "total douche" $20.0...   Feb 21 2013, 11:29 AM
casey944   They have a "total douche" $20....   Feb 21 2013, 12:20 PM
ThePaintedMan   [quote name='ThePaintedMan' post='1823760' date='...   Feb 21 2013, 01:37 PM
casey944   Thanks to all of you for the input. Ordered a Tan...   Feb 22 2013, 09:34 AM
ThePaintedMan   Thanks to all of you for the input. Ordered a Ta...   Feb 22 2013, 10:12 AM
brant   the 050 is not notorious for that... yes the 009 ...   Feb 22 2013, 11:38 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:05 PM
