| casey944 |
Feb 20 2013, 04:01 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
Afternoon!
My 914 has a 1.7L engine(original) and I am running a pair of 36IDF carbs. I have rebuilt them personally, had another relatively local 914 specialist rebuild them and I am still not entirely happy with the way they perform.... Transition and coming on to throttle up to when the main jets come on seems to be the issue. Is there a rebuilder/cleaner that everyone on here recommends? I figure some sort of ultra sonic blasting to clean out the ports/chambers that I am not able to get to would be the best. Any insight? Possibly also rejetting suggestions might be good as well. Thanks, Casey |
| casey944 |
Feb 21 2013, 11:14 AM
The only issue is really throttle response... On throttle tip in it always bogs rather than picking up. To overcome this you need to rev to ~3k and slip the clutch higher so that is doesnt bog. That is really the only issue with the car. From the research that I have done it seems like it is a problem with the idle circuit of the carb as it only happens at lower RPM through transition.
The Valves were adjusted roughly 300 miles ago when the heads came off to replace the seals for the pushrod tubes. I will order that book right now... Only copy I saw was on amazon for $102. |
casey944 Looking for a weber rebuilding/cleaning service Feb 20 2013, 04:01 PM
'73-914kid Did the car drive alright before? Sounds more like... Feb 20 2013, 04:15 PM
casey944
Did the car drive alright before? Sounds more lik... Feb 20 2013, 04:27 PM
quadracerx I have heard that this guy is the guru but have no... Feb 20 2013, 04:44 PM
jasons I sent my Dellortos to Air Cooled Engineering. Th... Feb 20 2013, 05:42 PM
maxwelj You should take a look at performance oriented. P... Feb 20 2013, 07:04 PM
Eric_Shea Paul's the master but is backed up a ways.
Ai... Feb 20 2013, 07:17 PM
Jake Raby Art at Aircooled Engineering has been prepping car... Feb 20 2013, 07:26 PM
ThePaintedMan
Afternoon!
My 914 has a 1.7L engine(original... Feb 20 2013, 10:13 PM
DBCooper Every metropolitan area should have somebody who c... Feb 21 2013, 07:16 AM
casey944 Thanks all for your input. I have been through th... Feb 21 2013, 07:58 AM
rhodyguy i don't think you're fully on the main jet... Feb 21 2013, 09:31 AM
ConeDodger You're sure that it is the carbs? Two people, ... Feb 21 2013, 09:43 AM
ThePaintedMan
You're sure that it is the carbs? Two people,... Feb 21 2013, 09:52 AM
rhodyguy adequate fuel delivery and 3.5# MAX. Feb 21 2013, 10:02 AM
DBCooper A hundred bucks? Dude! [url=http://www.cbper... Feb 21 2013, 10:07 AM
ConeDodger Unfortunately, everything else must be spot-on bef... Feb 21 2013, 10:37 AM
Eric_Shea
They have a "total douche" $20.00... Feb 21 2013, 11:22 AM
ThePaintedMan
They have a "total douche" $20.0... Feb 21 2013, 11:29 AM
casey944
They have a "total douche" $20.... Feb 21 2013, 12:20 PM
ThePaintedMan
[quote name='ThePaintedMan' post='1823760' date='... Feb 21 2013, 01:37 PM
casey944 Thanks to all of you for the input. Ordered a Tan... Feb 22 2013, 09:34 AM
ThePaintedMan
Thanks to all of you for the input. Ordered a Ta... Feb 22 2013, 10:12 AM
brant the 050 is not notorious for that...
yes the 009 ... Feb 22 2013, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:18 PM |
