| casey944 |
Feb 20 2013, 04:01 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
Afternoon!
My 914 has a 1.7L engine(original) and I am running a pair of 36IDF carbs. I have rebuilt them personally, had another relatively local 914 specialist rebuild them and I am still not entirely happy with the way they perform.... Transition and coming on to throttle up to when the main jets come on seems to be the issue. Is there a rebuilder/cleaner that everyone on here recommends? I figure some sort of ultra sonic blasting to clean out the ports/chambers that I am not able to get to would be the best. Any insight? Possibly also rejetting suggestions might be good as well. Thanks, Casey |
| Eric_Shea |
Feb 21 2013, 11:22 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I will order that book right now... Only copy I saw was on amazon for $102. They have a "total douche" $20.00 minimum. |
| ThePaintedMan |
Feb 21 2013, 11:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
QUOTE I will order that book right now... Only copy I saw was on amazon for $102. They have a "total douche" $20.00 minimum. (IMG:style_emoticons/default/agree.gif) You mean CB Performance, right? |
| casey944 |
Feb 21 2013, 12:20 PM
QUOTE I will order that book right now... Only copy I saw was on amazon for $102. They have a "total douche" $20.00 minimum. (IMG:style_emoticons/default/agree.gif) You mean CB Performance, right? Yep, i caught that. The guys at ACE were very nice and insightful. Their suggestion, since multiple people had been in and through the carbs was to focus on the dist... If i recall I have an 050 which they said had a dead spot. He suggestioned I go for an SVDA. My current Dist doesnt have a vacuum advance. Would going to an SVDA dist be a good first move? Suggestions on which one? Thanks |
| ThePaintedMan |
Feb 21 2013, 01:37 PM
QUOTE I will order that book right now... Only copy I saw was on amazon for $102. They have a "total douche" $20.00 minimum. (IMG:style_emoticons/default/agree.gif) You mean CB Performance, right? Yep, i caught that. The guys at ACE were very nice and insightful. Their suggestion, since multiple people had been in and through the carbs was to focus on the dist... If i recall I have an 050 which they said had a dead spot. He suggestioned I go for an SVDA. My current Dist doesnt have a vacuum advance. Would going to an SVDA dist be a good first move? Suggestions on which one? Thanks Sorry Casey, just saw this after I replied to your PM. The 050/009 are bad distributors for a car that doesn't see extended periods at high RPMs and is notorious for a flat spot down low. John at Aircooled.net sells new 034 SVDAs, which is what you would want. You may not have the *correct* vacuum ports on the 36s. Again, you can still run the SVDA, but will miss out on some of the off-idle advance the vacuum provides with the SVDA. |
casey944 Looking for a weber rebuilding/cleaning service Feb 20 2013, 04:01 PM
'73-914kid Did the car drive alright before? Sounds more like... Feb 20 2013, 04:15 PM
casey944
Did the car drive alright before? Sounds more lik... Feb 20 2013, 04:27 PM
quadracerx I have heard that this guy is the guru but have no... Feb 20 2013, 04:44 PM
jasons I sent my Dellortos to Air Cooled Engineering. Th... Feb 20 2013, 05:42 PM
maxwelj You should take a look at performance oriented. P... Feb 20 2013, 07:04 PM
Eric_Shea Paul's the master but is backed up a ways.
Ai... Feb 20 2013, 07:17 PM
Jake Raby Art at Aircooled Engineering has been prepping car... Feb 20 2013, 07:26 PM
ThePaintedMan
Afternoon!
My 914 has a 1.7L engine(original... Feb 20 2013, 10:13 PM
DBCooper Every metropolitan area should have somebody who c... Feb 21 2013, 07:16 AM
casey944 Thanks all for your input. I have been through th... Feb 21 2013, 07:58 AM
rhodyguy i don't think you're fully on the main jet... Feb 21 2013, 09:31 AM
ConeDodger You're sure that it is the carbs? Two people, ... Feb 21 2013, 09:43 AM
ThePaintedMan
You're sure that it is the carbs? Two people,... Feb 21 2013, 09:52 AM
rhodyguy adequate fuel delivery and 3.5# MAX. Feb 21 2013, 10:02 AM
DBCooper A hundred bucks? Dude! [url=http://www.cbper... Feb 21 2013, 10:07 AM
ConeDodger Unfortunately, everything else must be spot-on bef... Feb 21 2013, 10:37 AM
casey944 The only issue is really throttle response... On t... Feb 21 2013, 11:14 AM
casey944 Thanks to all of you for the input. Ordered a Tan... Feb 22 2013, 09:34 AM
ThePaintedMan
Thanks to all of you for the input. Ordered a Ta... Feb 22 2013, 10:12 AM
brant the 050 is not notorious for that...
yes the 009 ... Feb 22 2013, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:58 PM |
