Brakes won't pump up, Bad master cyl.? |
toon1 |
Feb 21 2013, 10:03 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I just completed the 5 lug conversion on the front and I can't get any brake pedal pressure. I've bled the system from the back pass. first, driver rear second, front pass. third and front driver last. I have clear fluid all the way through the system and no bubbles.
The front calipers are rebuilt with all new seals. I pressed on the pedal slowly with the bleeder valve open and can see fluid moving towards the catch bottle. There are no leaks anywhere. I'm stumped, I'm wondering if the master went bad somehow and it wont build pressure. They worked great before the conversion. |
toon1 |
Feb 22 2013, 03:13 PM
This happened to me last year...I hate to even admit how simple the fix was...did you bleed the top and bottom bleeders on all wheels that have them? I forgot the upper back ones when changing the fluid and MC. Fixed it immediately after those were opened... There is only one bleeder on my caipers. Thanks for all the suggestions guy's. I'll try them and let you know what I find. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:57 AM |
