Brakes won't pump up, Bad master cyl.? |
toon1 |
Feb 21 2013, 10:03 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I just completed the 5 lug conversion on the front and I can't get any brake pedal pressure. I've bled the system from the back pass. first, driver rear second, front pass. third and front driver last. I have clear fluid all the way through the system and no bubbles.
The front calipers are rebuilt with all new seals. I pressed on the pedal slowly with the bleeder valve open and can see fluid moving towards the catch bottle. There are no leaks anywhere. I'm stumped, I'm wondering if the master went bad somehow and it wont build pressure. They worked great before the conversion. |
ChrisFoley |
Feb 22 2013, 11:54 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Or grab two old brake hard lines from a parts car and do what McMark recommended - for free. (IMG:style_emoticons/default/laugh.gif)
I TIG weld the crimped tubing shut. |
mrbubblehead |
Feb 22 2013, 02:42 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
Or grab two old brake hard lines from a parts car and do what McMark recommended - for free. (IMG:style_emoticons/default/laugh.gif) I TIG weld the crimped tubing shut. i'm not understanding (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
ChrisFoley |
Feb 22 2013, 03:18 PM
i'm not understanding (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) We're using the brake line fittings as plugs by sealing the cut off end of the line. Eric's picture is the cap for a rear caliper inner adjuster - same threads. I like the line fittings better for a pressure application because they have the tapered seat. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:17 AM |
