Brakes won't pump up, Bad master cyl.? |
toon1 |
Feb 21 2013, 10:03 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I just completed the 5 lug conversion on the front and I can't get any brake pedal pressure. I've bled the system from the back pass. first, driver rear second, front pass. third and front driver last. I have clear fluid all the way through the system and no bubbles.
The front calipers are rebuilt with all new seals. I pressed on the pedal slowly with the bleeder valve open and can see fluid moving towards the catch bottle. There are no leaks anywhere. I'm stumped, I'm wondering if the master went bad somehow and it wont build pressure. They worked great before the conversion. |
ArtechnikA |
Feb 22 2013, 04:43 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE There is only one bleeder on my calipers. Gotta ask - because there are no pictures - you've got 'em mounted with the bleeders up, yes ? Right on the right, left on the left ? You wouldn't be the first... There's brake-port-plugs with the conical seats. Once upon a time I knew the VW part number. I'll try to post a picture tonight - but Feb 22 is National Margarita Day so I can make no promises :-) |
Lo-Fi Version | Time is now: 9th June 2024 - 05:31 AM |
