914-6 original overheating issues above 85 mph?, 914-6 |
unpolire |
Feb 24 2013, 12:00 AM
Member Group: Members Posts: 51 Joined: 6-July 08 From: Los Angeles CA Member No.: 9,260 Region Association: Southern California |
An aerospace engineer friend of mine was over and we were discussing 6-cylinder powerplants in the 914. A friend of his bought a 914-6 new and used to complain that he could not drive over 85 mph, after skiing in Reno, on his return, due to detrimental air pressure over the engine cover area as a result of the body's aerodynamics. Has anyone experienced this?
bulitt |
Feb 24 2013, 04:03 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Engine running too lean, Too much, or too little timing advance, broken fan impellers, air flaps as mentioned, wrong spark plugs, mouse nests in tins, too high compression ? Thats why I don't ski.
ArtechnikA |
Feb 24 2013, 06:43 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Engine running too lean, Too much, or too little timing advance, broken fan impellers, air flaps as mentioned, wrong spark plugs, mouse nests in tins, too high compression ? Too lean is hard to manage at 6000'+ unless you work at it. Hard to imagine broken fan bits in the 911 fan which runs at about 1.7x crankshaft speed. Spark plugs don't really affect oil temp. Flaps came in 1973, no original 6's had them. Same with compression - if it's too high, it's not original ;-) It also falls at altitude. Debris covering the cylinder and head tops and the oil cooler is a BIG factor. I've had two factory /6's and never had cooling issues at "energetic highway" speeds or on the track. It's a PITA to pull the fan shroud and clean out the detritus but other than intake gaskets and such, the materials cost is low, and the benefits high. The air is colder at altitude but it's less dense and doesn't cool as well, in addition to lowering available power. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:04 PM |
