> Taller fifth gear, Substituting a flipped HB gear in fifth
bluhun
post Feb 24 2013, 04:52 AM
At the Bay Area meet last week, one owner who is planning a 3.2 liter six conversion also talked about substituting a flipped HB (19:31) gear in fifth in place of the standard ZD (31:22) in order to lower engine revs at highway cruising speed and increase fuel economy. Does anyone have any experience with this transmission modification?
toon1
post Feb 24 2013, 11:25 AM
QUOTE(Mark Henry @ Feb 24 2013, 08:29 AM) *
I guess it's HA and HB, I think mine might be the HA which is a bit lower ratio when flipped. I think peeps call it an H gear when really it's an HB?
Anyone know what my final ratio and RPM's would be with a flipped HA and 205/60-15 tires?
It's gonna get you back close to stock gearing, maybe a touch taller. I was running 195/60/15's and that's about 4.7%under driven.
There is a gear chart/rpm/tire size XLS chart in the archives somewhere that Aaron cox posted a long time ago that you can change the tire size and it will give you a final output. The someone was able to also add flipped gears to the chart to give a taller gear ratio and different tire size ratio's.
If you can find it it will tell you what your ratio's will be.
- Lo-Fi Version Time is now: 2nd April 2026 - 10:27 AM
