'73 Resto & Suby 6 Conversion, or a primer on "How to convert your 914 to a Subaru 3.0" |
76-914 |
Jan 9 2013, 10:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What's it been? A year since I got Blackie running. I finally get it tuned to a daily driver status and should have been happy as a Lark then but what do I do? I sold the engine (w/90 hour's on the Hobbs) on the last Dawn Patrol GMR run. So I pulled the engine and began preparing Blackie for her transformation.
Before I go any further check out my Jack Stands. Min height 19.5", 12 ton and should hold up to a 6.7 quake or direct nuclear attack. And out she comes. One thing you have to love about these cars is that you can remove an interior in 15 minutes. 30 min's if you have a console. This was one shot before the interior is gutted. and an hour later I'm scraping tar floorboards. |
76-914 |
Feb 24 2013, 08:30 PM
I'm going with a very good heater hose but not anything exorbitant. My heater hoses will not see the light of day so I see no need (at this time) to use green stripe or other big $$$ hoses. I was able to fish a piece thru the long w/o binding or kinking.
The trick is revealed. First fish the heater hose thru this vacuum/pool hose then fish the combination thru while rotating. The external hose has added benefits. It keeps the heater hose from crimping and adds some degree of wear protection to it, also. On final install I will trim the vac hose to conceal it. The metal opening will get a rubber grommet to center the heater hose where it passes thru on both ends. Will help to keep other critters out as well. (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:55 AM |
