| AE354803 |
Feb 24 2013, 11:29 AM
Member ![]() ![]() Group: Members Posts: 238 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
Since this is my first major project on the 912, I figured I would make a project thread since I'll have lots of questions.
The back story: Car is a 67 912 with a 2.0 914 type IV, Weber 40 IDFs, bosch .050 dist installed. Transmission is original 912 with 914 gears 3,4,5 installed, newly rebuilt (synchros, selector forks, etc.) 73 911 front end suspension/brakes/steering, dual zone master cylinder, ER polybronze all around. I've been investigating a loud, clanking noise for the past few months. The noise happens regardless of engine/oil temperature or pressure. It is present below ~3000 rpm and then disappears entirely above 3000 rpm. When the noise is gone the engine sounds great. While this noise was present I have driven the car from San Diego to San Francisco and back, as well as San Bernardino and a few other trips, so I think I've put on approx. 2500 miles (it's been present and slowly getting worse (as best I remember) since I purchased the car (June 2012)). The noise has bugged me but I always figured since everything ran fine that maybe this is just characteristic of this engine. However I stopped driving the car a few months ago because the more I ruled out what it wasn't the more I worried about what it was and it's eventual catastrophic failure stranding me and destroying the engine. Seems to be coming from the center of the case. I've gone through the valve train and replaced a stripped stud, installed new adjusters and made sure everything was wearing and fitting properly (which it was). After this did not fix the issue I decided that before something destroys itself and everything around it I would remove and rebuild the 2.0 so that I wouldn't have to worry in the future. I wasn't using the car just because of the noise and the gut feeling that it was a time bomb. I suspect an issue with a main or rod bearing (possibly multiple) or excess piston slop, maybe a deteriorated piston skirt. The Project: 1. Remove and rebuild to mostly stock the 2.0 type 4. I have Weber 40 IDF's, GA 2.0 heads, WebCam Hydraulic+Carb grind w/ WebCam hydraulic lifters (turns out to be some ), Bosch .050 distributor (will most likely install Petronix or other electronic points) Turns out that I had low compression bus pistons, some unknown cam, the cam to cam gear mounting bolts were too long and machined the base and also half of the cam thrust bearing was missing. The crankshaft timing gear was no longer a press fit and could be removed by hand, the crankshaft itself had material missing due to the slop. 2. Rebuild specifics: New (used) stock oil pump Rebuild heads [new SS exhaust valves, guides and retainers, heads cut to accept new cylinders without gaskets] new gaskets/bearings/rings throughout, EMW 96 mm cylinders and KB 96 mm pistons new reground crankshaft and gearstack, 494 webcam and mechanical lifters w/ double thrust bearings and new cam gear Petronix electronic points and rebuild dist. Static balanced rods (0.1 grams) pistons (1 gram) New Sachs pressure plate New motor mounts and heavier mount bar to frame mounts (1/4" steel plate) Install engine to exhaust header flange supports (engine did not have them) CB Performance rotary fuel pump Cut to length pushrods and solid rocker arm spacers 3. Have a set of EMW bus headers that I will add heating tins to and install with a new header and muffler. Not until after the engine is back in and running. 4. Fix small issues found along the way (so far fix bumper mounting alignment and rear engine bar mounts need to have a steel tube installed w/ bolt through to remove play and prevent further wear.) This is my list for now, I am expecting it to grow, thanks in advance for any help. Andy |
| Dave_Darling |
Feb 27 2013, 01:08 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
96mm cylinders should not require any case modifications. I had thought the spigots in the case were larger than 99mm somehow?
Anyway, the 96es should work without machining. --DD |
| AE354803 |
Feb 27 2013, 02:23 PM
96mm cylinders should not require any case modifications. I had thought the spigots in the case were larger than 99mm somehow? Anyway, the 96es should work without machining. --DD Thanks Dave, I measured around 99.5 mm, however the batteries were out so I was using the 1mm tick marks on the shaft. With 96mm should I have any need to increase oil flow/cooling? |
AE354803 2.0 stock(ish) rebuild Feb 24 2013, 11:29 AM
AE354803 Progress:
Removed engine last night by partial dr... Feb 24 2013, 11:32 AM
AE354803 So I pulled the engine apart enough to remove the ... Feb 24 2013, 09:56 PM
AE354803 Seems like the rings are definitely going, I think... Feb 24 2013, 10:01 PM
reharvey I think you have a set of low compression VW Bus p... Feb 24 2013, 11:46 PM
Bleyseng looks that way and with the hydro cam you are leav... Feb 25 2013, 06:13 AM
AE354803
looks that way and with the hydro cam you are lea... Feb 25 2013, 11:14 PM
AE354803 I think I might be missing a case bolt, not sure b... Feb 27 2013, 12:30 AM
AE354803 The Outer diameter at the bottom of the cylinder i... Feb 27 2013, 12:43 AM
Cupomeat
I think I might be missing a case bolt, not sure ... Mar 2 2013, 08:33 PM
AE354803 Thanks Eric for the info.
Had no luck at the swap... Mar 4 2013, 08:53 PM
AE354803 Anyone know where I can get a replacement for this... Mar 4 2013, 09:06 PM
Dave_Darling
Also, I need a flywheel lock (the batman looking ... Mar 5 2013, 08:36 PM
AE354803 So I'm waiting for an engine yoke to show up b... Mar 5 2013, 11:57 PM
Dave_Darling The "spacers" are the head gaskets. Sev... Feb 25 2013, 10:15 AM
Dave_Darling Probably not, but it depends on about a zillion ot... Feb 27 2013, 08:22 PM
pnewman Please keep us up to date on your progress. It is... Mar 1 2013, 09:12 PM
'73-914kid Valve pockets in the pistons make me want to think... Mar 4 2013, 08:59 PM
'73-914kid Hex bar pivot
Those ball sockets tend to wear ou... Mar 4 2013, 09:47 PM
euro911 Pelican Parts has the flywheel lock Mar 4 2013, 11:23 PM
Vacca Rabite You should get to know European Motor Works.
IMO... Mar 5 2013, 02:14 AM
AE354803
IM... Mar 5 2013, 11:48 AM
Vacca Rabite
Are the Keith Black better quality parts than AA ... Mar 5 2013, 08:21 PM
euro911 Is it a wobble, or just side to side play?
What r... Mar 6 2013, 12:46 AM
AE354803
What ... Mar 6 2013, 10:47 AM
Vacca Rabite There is a gap between the bushings and the crank.... Mar 6 2013, 09:56 AM
euro911 A 'deep clunk' is usually indicative of a ... Mar 6 2013, 11:30 AM
AE354803 The engine yoke finally came in after a short misd... Mar 12 2013, 12:15 PM
Vacca Rabite Head gaskets. A lot of folks here do not run them... Mar 12 2013, 12:43 PM
AE354803
Head gaskets. A lot of folks here do not run the... Mar 12 2013, 01:10 PM
Michelj13 Measure and find out EXACTLY what your compression... Mar 13 2013, 08:06 AM
AE354803 Engine torn down and all case bolts removed. Can... Mar 16 2013, 05:01 PM
Dave_Darling You missed a bolt.
If the case doesn't come a... Mar 16 2013, 07:40 PM
reharvey
You missed a bolt.
If the case doesn't come ... Mar 16 2013, 09:09 PM
AE354803
You missed a bolt.
If the case doesn't come ... Mar 16 2013, 09:12 PM
Dave_Darling Yes, they're held in by plastic "vibratio... Mar 17 2013, 10:31 AM
AE354803 Missed the one behind the flywheel, hard to see it... Mar 19 2013, 12:00 AM
brant definitely missed a bolt
I destroyed one case for ... Mar 17 2013, 10:37 AM
Valy The cam looks to be aftermarket. The bolts between... Mar 19 2013, 06:20 PM
Valy Here is how the cam bolts should look like so they... Mar 19 2013, 06:25 PM
Vacca Rabite :agree:
Your cam bolts self machined themselves i... Mar 19 2013, 06:32 PM
AE354803
:agree:
Your cam bolts self machined themselves ... Mar 19 2013, 08:36 PM
Valy The cam gear angled teeth create an axial pushing ... Mar 19 2013, 10:19 PM
AE354803 Based on this pictures from Van's 914 engine r... Mar 19 2013, 11:25 PM
Valy The bolts don't hit the bearing. I think that ... Mar 20 2013, 09:59 AM
AE354803 I checked the side play of the rods on the crank, ... Mar 20 2013, 11:55 PM
bugsy0
The bolts don't hit the bearing. I think that... Mar 28 2013, 10:41 PM
AE354803
The bolts don't hit the bearing. I think tha... Mar 29 2013, 09:22 AM
Valy Buffle Biddle plate is not a must. It should helon... Mar 21 2013, 10:00 AM
AE354803 I'm pretty sure my case should be dual oil pre... Mar 21 2013, 08:47 PM
Valy You are not alone. I have a case that is not dual ... Mar 21 2013, 10:13 PM
Vacca Rabite Neither is mine.
Zach Mar 22 2013, 06:10 AM
Dave_Darling The book is wrong, many 914 cases are single-relie... Mar 22 2013, 08:36 AM
AE354803
The book is wrong, many 914 cases are single-reli... Mar 22 2013, 09:55 AM
Vacca Rabite You shoukd have zero play on the cam drive gear.
I... Mar 22 2013, 06:13 PM
two-strokejohn Check bughaus.com for your vibration dampers and o... Mar 22 2013, 06:53 PM
Valy The gaskets set contains the dumpers. I guess you... Mar 22 2013, 07:58 PM
Vacca Rabite
The gaskets set contains the dampers. I guess you... Mar 22 2013, 08:23 PM
Valy Victor Reinz has them Mar 22 2013, 11:00 PM
AE354803 Parts are starting to roll in, heads will be done ... Mar 28 2013, 12:09 PM
Vacca Rabite Last question first:
Take your case to a local mac... Mar 28 2013, 09:27 PM
AE354803
All rotating mass needs to be balanced. Crank,... Mar 29 2013, 09:28 AM
bugsy0 So what's the conclusion on why the original c... Mar 28 2013, 10:36 PM
bugsy0 I guess I could answer my own question with someth... Mar 28 2013, 10:49 PM
Vacca Rabite Well, aluminum. Not magnesium. T4 cases are alum... Mar 29 2013, 07:21 AM
Cap'n Krusty If the crankshaft gear were even slightly flawed, ... Mar 29 2013, 09:44 AM
AE354803 Thanks Cap'n, I'm replacing the cam gear a... Mar 29 2013, 10:00 AM
AE354803 Just wonderful, finally took the crank gear assemb... Mar 29 2013, 10:19 PM
Vacca Rabite Thats not good!
Nice metal shaving on the cran... Mar 30 2013, 07:28 PM
AE354803 Trying to find a used crank that isn't undersi... Mar 30 2013, 11:22 PM
jcd914
Trying to find a used crank that isn't unders... Mar 30 2013, 11:33 PM
Vacca Rabite If you are building a stockish motor you do not ne... Mar 31 2013, 08:00 PM
AE354803 Ended up ordering a DPR crank DPR Machine Shop th... Apr 1 2013, 09:23 AM
AE354803 Took apart the oil pump and took measurements. It... Apr 1 2013, 11:01 PM
Vacca Rabite Pump failure comes at the driveshaft. Yours looks ... Apr 2 2013, 07:34 AM
craig downs Not necessarily
The pin that is pressed in can ove... Apr 2 2013, 09:05 AM
AE354803
Not necessarily
The pin that is pressed in can ov... Apr 2 2013, 09:41 AM
Vacca Rabite
Not necessarily
The pin that is pressed in can ov... Apr 2 2013, 09:50 AM
Valy The measurement you should care about is the axial... Apr 2 2013, 10:42 AM
AE354803 I can really only measure axial movement for the d... Apr 2 2013, 10:47 AM
Valy Lapping compound can't do any good. If you ins... Apr 2 2013, 12:48 PM
AE354803 What brand of bearings are the most reliable?
Con... Apr 3 2013, 12:55 AM
Valy
Co... Apr 3 2013, 02:25 PM
AE354803 Got the heads back, installed the solid spacers wh... Apr 13 2013, 04:53 PM
AE354803 I'm rebuilding the oil pump in preparation for... Apr 30 2013, 08:39 PM
Vacca Rabite There are those who will disagree with me and say ... Apr 3 2013, 08:49 AM
pilothyer Oil pump to crankcase nuts 14 ft lb according to:
... Apr 30 2013, 09:33 PM
AE354803 Got that spec, thanks though. I'm looking for... Apr 30 2013, 09:39 PM
pilothyer My bad.....wrong bolts per your question Apr 30 2013, 09:34 PM
pilothyer As a builder of many type 4 engines as well as a p... Apr 30 2013, 10:04 PM
Java2570 I'm pretty sure that in his video, Jake mentio... May 1 2013, 06:18 AM
AE354803 Sound good to me. Maybe I'll throw some blue ... May 1 2013, 11:07 AM
AE354803 Where can I remove material from the Keith Black p... May 5 2013, 11:43 PM
AE354803 I've been looking at the pistons and I think I... May 8 2013, 01:08 PM
AE354803 I'm measuring the piston-cylinder gap. Spec i... May 8 2013, 06:43 PM
Valy All pistons have oval skirts as you measured.
The ... May 8 2013, 07:56 PM
AE354803 The top had the same large gap all the way around,... May 8 2013, 09:19 PM
AE354803 During platigage fit today, found out the cam thru... May 11 2013, 06:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:06 PM |
