| scotty b |
Mar 7 2013, 08:55 AM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Is it REALLY necessary ? I've done a couple of these but have yet to understand why. I have NEVER seen a trailing arm bent from anything otther than a hard collision. I see no way they could be twisting or flexing in any way in hard cornering. I'm curious if any of the hardcore racers have seen a true need for them. Anyone ever seen a ARM crack from use not rust ? Sure the consoles crack, the body cracks but the trailing arm ? Seems like unneccesary weight to me (IMG:style_emoticons/default/confused24.gif)
Talk amongst yourselves I'll check back in later (IMG:style_emoticons/default/popcorn[1].gif) |
| brant |
Mar 7 2013, 09:01 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,296 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I think a lot of the Noticeable flex that was attributed over the years was probably mistakenly attributed to the swing arm when it was actually the chassis and swing arm mount that was flexing....
however they do still flex a truly skilled builder and racer who is 10 faster in his 914 than I ever will be, insists that he can tell the difference on a car with or without trailing arm reinforcement. he has built 20-30 914 race cars and always installs both the mount brace bars on the chassis and also the swing arm reinforcements. Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. The thread is one of the best threads that has ever been on this site. It shows that there is flex and that sticky race tires could produce that flex. So in summary.... a little flex although the chassis mount brace kits are equally responsible for a little racing flex. brant |
| ChrisFoley |
Mar 7 2013, 09:35 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Additionally... Chris ran actual flex tests on a bench of trailing arms to design his brace kit that he sells. I designed the trailing arm stiffening procedure I now use during those tests. The metal we add weighs far less than the boxed reinforcing kits, and doesn't over-strengthen the arm. I think that welding the box reinforcements warps the trailing arms, adding toe-out. Previously I had determined that the chassis around the suspension mounts and the outer console bracket both twist in hard cornering. There are documented failures of trailing arms cracking where the box meets the pivot tube. Gusseting there provides a significant benefit. |
scotty b trailing arm stiffening kit Mar 7 2013, 08:55 AM
ConeDodger
Additionally... Chris ran actual flex tests on a... Mar 7 2013, 09:54 AM
Woody
[quote name='Racer Chris' post='1831099' date='Ma... Mar 7 2013, 04:19 PM
ConeDodger
[quote name='Racer Chris' post='1831099' date='M... Mar 8 2013, 12:16 AM
mrbubblehead i wonder it is better to have the trailing arm be ... Mar 7 2013, 09:20 AM
brant
i wonder it is better to have the trailing arm be... Mar 7 2013, 09:27 AM
ThePaintedMan Yep, Chris' thread testing the arm is pretty d... Mar 7 2013, 09:23 AM
slothness
[quote name='Racer Chris' post='1831099' date='Ma... Mar 7 2013, 10:00 AM
Racer Chris I just don't learn.
:headbang:
... Mar 7 2013, 10:05 AM
Eric_Shea We do a very simple and easy mod for our customers... Mar 7 2013, 11:14 AM
euro911 We do a very simple and easy mod for our customers... Mar 8 2013, 02:52 AM
MDG Nice, Eric. I like this - thanks for sharing. :thu... Mar 7 2013, 11:27 AM
balljoint I made the mistake of putting those old school clu... Mar 7 2013, 01:11 PM
76-914
I glad you mentioned this. Before my time so I lo... Mar 7 2013, 01:33 PM
Socalandy I went with Eric's solution and it was easy to... Mar 7 2013, 02:26 PM
76-914
I went with Eric's solution and it was easy t... Mar 8 2013, 09:21 AM
Steve JW aka Otto, RIP, who holds track records in 914... Mar 8 2013, 08:00 AM
brant
JW aka Otto, RIP, who holds track records in 914... Mar 8 2013, 09:27 AM
Eric_Shea
JW aka Otto, RIP, who holds track records in 914... Mar 8 2013, 04:44 PM
Socalandy
Where does one find a new paint code plate like t... Mar 8 2013, 10:07 AM
euro911 Second in line :evilgrin: Mar 8 2013, 01:02 PM
Socalandy
Kent has what he need... Mar 8 2013, 03:42 PM
gothspeed I like that idea of adding two 1" tubes throu... Mar 8 2013, 06:21 PM
Matt Romanowski The tubes don't triangulate at all, so I would... Mar 8 2013, 07:49 PM
euro911 :confused: I can easily see how adding stiffener t... Mar 8 2013, 08:01 PM
Jeff Hail Correct the tubes do not triangulate. What they do... Mar 8 2013, 08:03 PM
Racer Chris
As far as the box reinforcement kits if you weld ... Mar 8 2013, 08:14 PM
Jeff Hail Vaneers![size=4] Mar 8 2013, 08:19 PM
Eric_Shea ***UPDATE***
Here's a variation on this mod w... Jan 2 2017, 03:33 PM
Larmo63 I love this latest idea. I'm going to try that... Jan 2 2017, 08:01 PM
mgp4591 I drilled through the arms at places that will giv... Jan 3 2017, 01:23 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 03:28 AM |
