> 914 Chassis Stiffness, want input on chassis stiffness measurements
Curbandgutter
post Mar 14 2013, 12:30 PM
I want to check the stiffness of the 914 chassis two ways: the flexural stiffness (as in measure the shock tower movement as you lift it from the middle), and the torsional stiffness ( measuring the shock tower movement as you lift three wheels).
Then I want to input a 914 chassis into a 3d structural software that I use. I will design a tube chassis and check the flexural and torsional stifness with different tubing and thickness layouts.
Then construct the tube chassis and compare the real world results.
I want input from others as to how they would go about doing this. Or maybe give me some pointers. Or maybe someone already knows the factory stiffness?
What do you think?
Katmanken
post Mar 15 2013, 05:39 PM
You haven't seen me if anybody asks...
The 914 chassis is also pretty easy to model in sheet metal mode, particularly in the areas of worst torsional and flexural stiffness - which is under the doors.
Having modeled many things by hand and with FEA, I bet you get 90% there, Or, you can always measure the real thing with a jack and indicators which eliminates all the FEA guesses and gives real results.
Think about it. If you jack up one front wheel and measure for deflection at the rollbar, the torsional stiffness will be related to the point at where the front wheel moves up a little at a time until the chassis finally twists enough to move the rollbar torsionally. For flexural stiffness, jack it up in the front a little at a time and measure the point at which the front of the rollbar finally moves up.
Curbandgutter   914 Chassis Stiffness   Mar 14 2013, 12:30 PM
76-914   I want to check the stiffness of the 914 chassis ...   Mar 14 2013, 12:50 PM
Curbandgutter   I read the entire 52 pages and did not find any me...   Mar 14 2013, 04:57 PM
Vysoc   :popcorn: Vysoc :flag1:   Mar 15 2013, 04:49 PM
76-914   Sorry, "it" has many meanings. In this c...   Mar 15 2013, 05:16 PM
kg6dxn   :wttc:   Mar 15 2013, 05:26 PM
Curbandgutter   :wttc: Thank You. It's nice to be back. L...   Mar 16 2013, 09:43 AM
Katmanken   The 914 chassis is also pretty easy to model in sh...   Mar 15 2013, 05:39 PM
Curbandgutter   Thanks for the suggestion. I have access to a 3D ...   Mar 16 2013, 09:35 AM
Curbandgutter   Well after a loooong time, the final numbers are i...   Sep 10 2016, 11:40 PM
GeorgeRud   I installed Brad Mayeur's long kit on the outs...   Sep 11 2016, 07:40 AM
Cracker   I admire your commitment to detail and look forwar...   Sep 11 2016, 08:07 AM
sixnotfour   Up Fixxin Der Porsche vol. VIII pg 241 I am pr...   Sep 11 2016, 08:56 AM
r_towle   Up Fixxin Der Porsche vol. VIII pg 241 I am p...   Sep 11 2016, 05:25 PM
914forme   Yes they did do a shaker table analyst of the 914 ...   Sep 11 2016, 10:13 AM
Dave_Darling   It was either with Dwight Mitchell or Terry Zaccon...   Sep 11 2016, 11:21 AM
Curbandgutter   Hey guys thanks for the input. Man I would love t...   Sep 11 2016, 03:05 PM
Cracker   I'm not sure what kind of car you're tryin...   Sep 11 2016, 03:23 PM
URY914   Center torque tube tying the back and front togeth...   Sep 11 2016, 07:20 PM
- Lo-Fi Version Time is now: 20th June 2026 - 01:06 PM
