> Intermitent Starter issue
914itis
post Mar 11 2013, 07:56 PM
My starter was fine, until the weekend.
The weather was nice and I decided to take a drive; started fine. when I got to my destination, I turned the key and it attempted to start the car and the battery cuts off.
I have a 60 amp fuse on the red wires going to the battery, check the fuse it wast toast. I replaced the fuse and it blew it instantly as soon as I turn the key on.
Since there is a wire coming from the the main fuse that I installed from the battery to my amp and air horn, I isolated the wire and replace the fuse again the car starts fine.
When I got home, I installed a dedicated fuse for that amp wire.
Since then, the starter becomes a hit and miss. sometimes starts on the first try, sometimes i have to turn the key on and off before the starter spins. Sometimes it would start spinning for a short time and stops before the engine can start.
The starter positive wire is straight from the battery.
I know that there is an issue with the 74's where a relay is installed, but why would it burn the fuse to begin with?
All my grounds are intact.
Any ideas??
914itis
post Mar 17 2013, 05:01 PM
Update:
I started the car Friday and noticed a noise on the starter after starting for about 8 seconds, then it went away. keep restarting and it has not happened since. I think that it is getting stuck on the flywheel causing overload and blows the fuse. (is that a possibility?) I went ahead and swapped with the starter on my other teener, it is only about a year old and about 1000 miles on it. I am not sure if the issue is solved, but so far so good.
we will see what happen.
914itis   Intermitent Starter issue   Mar 11 2013, 07:56 PM
914itis   :bump:   Mar 12 2013, 09:09 AM
rmital   :bump: ...you've been driving the heck outa ...   Mar 12 2013, 09:36 AM
914itis   Ray, He'll yeah! Nothing changed other...   Mar 12 2013, 09:44 AM
struckn   Cracked Ignition Switch can cause intermitent prob...   Mar 13 2013, 06:16 PM
timothy_nd28   Has the seatbelt interlock circuit been bypassed y...   Mar 13 2013, 09:33 PM
914itis   Yes it has .   Mar 13 2013, 10:28 PM
timothy_nd28   I'm somewhat unclear with the order of events ...   Mar 13 2013, 10:40 PM
914itis   I'm somewhat unclear with the order of events...   Mar 13 2013, 10:53 PM
timothy_nd28   I'm not familiar with the Djet start circuit s...   Mar 13 2013, 11:58 PM
914itis   Thanks. Will follow your advice and do more troubl...   Mar 14 2013, 12:37 AM
AE354803   My question is, can a starter going bad blow tha...   Mar 14 2013, 06:00 PM
914itis   My question is, can a starter going bad blow th...   Mar 14 2013, 06:10 PM
AE354803   Where is the starter relays located ? I don...   Mar 14 2013, 06:30 PM
914itis   Update: I started the car Friday and noticed a n...   Mar 17 2013, 05:01 PM
76-914   any scarring/marring on the shaft that would indic...   Mar 17 2013, 09:20 PM
914itis   No, no sign of any wear of grind.   Mar 17 2013, 09:33 PM
76-914   bad solenoid ?   Mar 18 2013, 09:35 AM
914itis   I am happy to report that after replacing the star...   Mar 20 2013, 09:35 PM
rmital   I am happy to report that after replacing the sta...   Mar 21 2013, 07:55 AM
914itis   No problem Ray, I would like to add that he load f...   Mar 21 2013, 08:44 AM
- Lo-Fi Version Time is now: 15th July 2025 - 11:46 AM
