Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
Brad Roberts |
Apr 24 2003, 11:18 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Hum..
where do I start .. ok.. I wont. I'll just say what I use and you can make your own judgement. I only use a regulator/return line/gauge when I'm running a racing type of fuel pump like a Holley Blue pump or Red pump. Everything you buy from a parts store like the FACET or knock off's of it (even the little rotary pumps) only put out 3.5 psi which is what all carbs (even triple throat) work well with. No need for a regulator or return line on street cars. Porsche didnt have a return line or a regulator on the 9146's and they used a big honkin pump that looks just like our fuel injection pumps (but pumps 3.5 psi) imagine that..LOL Replace that barb and run with it. Hook up the return line or plug it. You'll be fine (as long as they have a generic pump up front) Please NEVER try to regulate down a factory injection pump. A well known Rennlister burnt his wifes car to the ground when he put carbs on it and tried to regulate the factory pump to 3.5 psi. He is a ASE certified mechanic. LOL B |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:40 AM |
