Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
rhodyguy |
Apr 24 2003, 12:36 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
this is the pump i was running on the 72. will be removed and put on the 73'. this location was prob not the best plan, will place on the 73 in a location down stream for the f line outlet at the lower firewall. i can't imagine a clamp to regulate the pressure to be the best way to go,flow restriction not presure reduction. this pump is quiet. the other small cyl is a f.p.r that came with the unit. cb performance. i do intend to install a gauge infront of the carbs just so i know whats going on. lost my f-in job today. lots of time to work on the silver car now, once i calm down.
kevin Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:02 AM |
