> How to avoid overspray?
doug_b_928
post Mar 23 2013, 07:45 AM
I'm sorry if this is a silly question/topic. I'm still in the researching stage for my restoration. I was at the local autobody supply store yesterday and was asking them about spraying epoxy primer with a gun vs. using etching primer in a rattle can. I don't have a gun and have never used one. I know Jeff Hail's thread says to spray epoxy primer after each area is repaired. They said that either way (i.e., even with a rattle can) there is an issue with overspray. I don't have a dedicated shop and there is literally no place at my house where I would want overspray. They told me a story about overspray going hundreds of feet. So, I was thinking that what I could do is have a tarp on the concrete under the car (plan is to make a bench a la Hail) and drape a poly tarp over the car. I can't tape poly to the ceiling to make a pseudo paint booth because the garage door would hit it when it's open. I suppose I could make a makeshift poly tent that fits under the garage door. But, I would think that lack of ventilation would be a big problem. Would this work? Be too unsafe? Better to rent a workspace and do all the metal work/priming elsewhere? Your thoughts and experiences would be helpful.
914GT
post Mar 23 2013, 07:44 PM
I think you just need to use some good judgment, and cover up things of value even if just from a spray can. If you have another car in the garage, move it out or cover it with plastic. With a small gun that has the pressure dialed down a bit, and just covering some welds or small areas, you won't have a fog of spray all over the place like you can get when painting a complete car. Cover adjacent areas with plastic or tarps, cover anything you don't want any dust or uncatalysed primers settling on. Maybe I'm not explaining this well, but spraying a couple of welds or bare metal areas will keep the overspray concern close to where you are working. But if you are spraying complete panels at high pressures you will trash everything in the garage if it's not covered up, and you don't have some kind of controlled ventilation.
doug_b_928
post Mar 23 2013, 08:00 PM
QUOTE(914GT @ Mar 23 2013, 08:44 PM) *
Okay, makes sense, thanks! Any recommended brand/model of small touch-up gun (for minimizing overspray and for ease of cleanliness)?
doug_b_928   How to avoid overspray?   Mar 23 2013, 07:45 AM
Vacca Rabite   For what you are doing, see if you can get epoxy i...   Mar 23 2013, 07:50 AM
doug_b_928   For what you are doing, see if you can get epoxy ...   Mar 23 2013, 09:30 AM
Cairo94507   If you watch Dexter (great show) keep him in mind ...   Mar 23 2013, 10:50 AM
PanelBilly   Don't worry so mu h about overspray. Tape off ...   Mar 23 2013, 01:19 PM
Spoke   When I paint in the garage, pretty much everything...   Mar 23 2013, 02:04 PM
Katmanken   Overspray usually happens with crappy nozzles that...   Mar 23 2013, 04:05 PM
doug_b_928   Hmmm.... I've seen a few episodes of Dexter bu...   Mar 23 2013, 05:51 PM
Cairo94507   :) the principle is the same though.....   Mar 23 2013, 05:59 PM
914GT   With epoxy just use a small HVLP touch-up gun and ...   Mar 23 2013, 06:42 PM
doug_b_928   With epoxy just use a small HVLP touch-up gun and...   Mar 23 2013, 07:01 PM
914GT   I think you just need to use some good judgment, a...   Mar 23 2013, 07:44 PM
doug_b_928   I think you just need to use some good judgment, ...   Mar 23 2013, 08:00 PM
914GT   For small primer jobs I get the cheap HVLP guns fr...   Mar 23 2013, 08:17 PM
doug_b_928   For small primer jobs I get the cheap HVLP guns f...   Mar 26 2013, 06:55 AM
ThePaintedMan   I'd like to contain overspray and dust from ...   Mar 26 2013, 07:39 AM
doug_b_928   Yea, I'd have to make it big enough to be able...   Mar 26 2013, 09:20 AM
Vacca Rabite   You are over thinking this IMO. In a garage you d...   Mar 26 2013, 09:32 AM
worn   I'm sorry if this is a silly question/topic. ...   Mar 26 2013, 02:56 PM
ThePaintedMan   There are epoxy primers in rattle cans. You twis...   Mar 26 2013, 03:15 PM
doug_b_928   Thanks for all of the advice guys. I will use a 3...   Mar 26 2013, 07:15 PM
- Lo-Fi Version Time is now: 14th October 2026 - 01:03 PM
