Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Yea it is kind of a waste (Weber 36/38 DVG) but I have a number of projects that are sucking up $$$ so I am trying to make it a while with this set up. Had a huge stumble before changing to the 60s on the Accelerator jets. The stumble is mostly gone now. Waiting for a 70 to come in. But while its better, it seems to not want to idle. Regardless of how I try to adjust it acorroding to the instructions, it seems to want to die. At anything above idle it seems to be fine. The problem was there before the change but it was no better after. Did a good cleaning on everything else but did not change anything other than the accelerator diaphram. One thing I noticed is that fuel seems to be dripping into the primary. I am not sure if it was like this before as I had not looked in.
I am assuming this is not normal, so any thoughts on what I goofed up? |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
You can choke the 44s down to 40 levels, but you still don't have the velocity going through the carb that you need.
I had 44s on my 2056 for a year. At about 3500 RPM the engine really seemed to come into its own. I changed to 40s and had a much better rev range. (and then I changed to EFI because I hated dicking with the carbs...). Do yourself a favor. Send you brand new carbs to Art Thran at ACE. Tell him what you want. He will build them to be what you need and then all you need to do is install them. You can take months off your tuning that way. Zach |
Lo-Fi Version | Time is now: 12th July 2025 - 03:40 PM |
