| yeahmag |
Mar 28 2013, 04:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,479 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
Did Elephant Racing buy the RSR Front Bushing design from Rebel Racing? They look identical!
http://rebelracingproducts.com/Suspension/Steering.html http://www.elephantracing.com/suspension/s...1sphericals.htm -Aaron |
| TravisNeff |
Mar 29 2013, 12:21 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
While they look the same, the Rebel racing fronts use a Teflon insert for the bushing and the elephant fronts uses steel bearings (they say for proper collinear operation).
| ChrisFoley |
Mar 29 2013, 01:30 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
While they look the same, the Rebel racing fronts use a Teflon insert for the bushing and the elephant fronts uses steel bearings (they say for proper collinear operation). AFAIK the inserts are not Teflon. They are Teflon impregnated Acetal copolymer. It is a very expensive engineering plastic with excellent lubricity and machining properties, however overkill for the application imo. |
yeahmag Rebel Racing Front Bushings vs. Elephant Racing Sphericals Mar 28 2013, 04:11 PM
396 I remember discussing this topic with one major af... Mar 28 2013, 04:17 PM
Jeff Hail There is essentially 12 major manufacturing player... Mar 28 2013, 05:52 PM
worn
Did Elephant Racing buy the RSR Front Bushing des... Mar 29 2013, 07:52 AM
Harpo The frt does look identical but the rear looks wid... Mar 29 2013, 08:32 AM
Harpo Lets also not forget that the elephant bushings ar... Mar 29 2013, 01:40 PM
yeahmag Anybody have instructions for the Rebel Racing RSR... Mar 29 2013, 04:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:49 PM |
