> Need help with my 2.0, problems with engine
ChristopherB
post Apr 2 2012, 06:27 PM
I bought my 914 last summer and have some problems. Everything I know, which is not much, I have learned reading this great forum since then. I was looking for a fun affordable Sunday driver. I love the look of my car, and it is great to drive. However, I started having problems from day one, and the engine is coming out this week for further examination/ rebuild.
Here is the info on the engine from the PO who did a rebuild about 6K miles ago.
2.0 with original D-Jet
Web Racing FI Cam with hydraulic lifters and push rods
Big Bore throttle body from High Performance House
Heated O2 sensor with air/fuel gauge
original heads rebuilt with new valves ported and polished
case steam cleaned and align bored
Remote sender for oil pressure
Mahle pistons , new rings and sleeves
There are a lot other items done to the car unrelated to my engine woes. You can see the ad here: http://www.914club.com/bbs2/index.php?showtopic=269159
My problems are numerous.
A local shop tells me cylinders 1&3 have low compression and engine needs a rebuild.
This sucks but I am resigned to the fact and am preparing to take on the challenge with a neighbor. I am preparing the engine for removal and it will be out within a week.
The PO indicated that the vac unit on the dist was not working. His mechanic had it tuned with the vac line going to the advance side when it should be on the retard side. I tried switching it but the car would not idle without stalling.
The car has very high crankcase pressure on start up and blew the cooler or the seals 2 weeks ago. The car has oil leaking from the push rod tubes even though the seals were replaced recently. Front main seal is leaking. Pretty much everywhere.
I am confused about cylinder and piston choices and sizes. What is what? Is a 2.0 engine 2056cc and not 2000? And what would be good in my application? I would like to get 140HP if I am going to do a rebuild.
Can I eliminate the stock cooler, and run only a remote cooler?
I have spent a lot of time reading build threads and searching remote coolers, but at this point it seems daunting.
I just purchased the following from a member here;
"Stock distributor from my 73 2.0L with functioning vac advance, Crane XR3000 electronic ignition, MSD rev limiter, Crane Fireball LX91 ignition coil, cap and rotor".
Should I start by purchasing the Raby rebuild video?
I am really bummed to have these problems with what I thought was a solid car, and am really bummed I am not enjoying the nice weather.
I am located in Towson, Maryland if anyone wants to recommend shops, mechanics, or better yet offer help or services.
type47
post Mar 31 2013, 07:19 PM
Viermeister
Only 20 more days 'til Hershey. That should be enough to get the car fine tuned to join the madness ...
ChristopherB   Need help with my 2.0   Apr 2 2012, 06:27 PM
struckn   Chris I just sent you a PM with some info on local...   Apr 2 2012, 06:59 PM
ChristopherB   Thanks Doug   Apr 2 2012, 07:02 PM
Dave_Darling   The Raby video is a good guide to a rebuild that h...   Apr 2 2012, 08:56 PM
euro911   I would get a second opinion (from a knowledgeable...   Apr 2 2012, 09:47 PM
914itis   I would get a second opinion (from a knowledgeabl...   Apr 2 2012, 10:12 PM
ChristopherB   Thanks everyone so much! I have all the parts...   Apr 3 2012, 12:18 PM
mepstein   Should I start by purchasing the Raby rebuild vide...   Apr 3 2012, 12:28 PM
ChristopherB   Great Thanks   Apr 3 2012, 06:47 PM
euro911   Well the good thing is that once you drop the engi...   Apr 3 2012, 08:18 PM
ChristopherB   That is what I'm hoping.   Apr 5 2012, 03:03 PM
rwilner   Chris The manual for the crane setup is available ...   Apr 6 2012, 07:43 AM
ChristopherB   Great, Thanks Rich. The engine is down but still s...   Apr 8 2012, 07:48 PM
euro911   Great, Thanks Rich. The engine is down but still s...   Apr 9 2012, 12:29 AM
914itis   You may want to test the AAR ok'd you are hidl...   Apr 8 2012, 10:05 PM
76-914   You may want to test the AAR ok'd you are hid...   Apr 9 2012, 09:24 AM
914itis   You may want to test the AAR ok'd you are hi...   Apr 9 2012, 01:18 PM
Bleyseng   Normally hydro lifters are set to 1.5 turns in aft...   Apr 9 2012, 06:40 AM
ChristopherB   Normally hydro lifters are set to 1.5 turns in af...   Apr 9 2012, 08:14 PM
euro911   Reminds me of that guy from Romania named Buchotiv...   Apr 9 2012, 11:18 AM
Dave_Darling   Your hoses are not right. Especially if that...   Apr 9 2012, 08:22 PM
ChristopherB   Thanks dave. That was a picture when I got the ca...   Apr 10 2012, 12:31 PM
vsg914   That hose on the pcv valve goes on the plenum port...   Apr 10 2012, 12:40 PM
ChristopherB   Thanks again for all the help. I was going through...   Apr 11 2012, 05:43 PM
Bleyseng   I'd order some FI fuel clamps instead of those...   Apr 11 2012, 06:02 PM
ChristopherB   I'd order some FI fuel clamps instead of thos...   Apr 11 2012, 07:17 PM
ChristopherB   I really got delayed repairing the car, but I am p...   Mar 19 2013, 08:09 PM
Dave_Darling   Most of the 74+ 2.0 cars did not have any vacuum a...   Mar 19 2013, 10:08 PM
ChristopherB   Great, Thanks. I will try it without adding the s...   Mar 20 2013, 09:13 AM
reharvey   That's a very colorful engine compartment...   Mar 20 2013, 09:37 AM
ChristopherB   Thanks. I love the car. I think it looks and dri...   Mar 31 2013, 06:21 PM
ChristopherB   Here are some photos just to make this more intere...   Mar 31 2013, 06:29 PM
ChristopherB   I did not even know what a valve cover was when I ...   Mar 31 2013, 06:30 PM
dpires914   Nice car. What color is that? Nepal orange, Signa...   Apr 9 2013, 07:14 PM
ChristopherB   RE: Need help with my 2.0   Mar 31 2013, 06:40 PM
type47   Only 20 more days 'til Hershey. That should be...   Mar 31 2013, 07:19 PM
ChristopherB   I have a question about raising the engine into pl...   Mar 31 2013, 07:48 PM
Dave_Darling   You should be able to just push the fuel rails aro...   Mar 31 2013, 09:22 PM
ChristopherB   You should be able to just push the fuel rails ar...   Apr 1 2013, 04:45 AM
SUNAB914   Just my .02 cents, in the pic of engine it looked ...   Apr 1 2013, 08:12 AM
ChristopherB   Just my .02 cents, in the pic of engine it looked...   Apr 1 2013, 03:06 PM
ChristopherB   I need some help learning where things go. I got ...   Apr 5 2013, 01:39 PM
Dave_Darling   The connector with the yellow insulator on it is n...   Apr 5 2013, 04:46 PM
ChristopherB   Thanks, First lesson learned this week is to take ...   Apr 5 2013, 05:04 PM
Dave_Darling   "Could be a ground" could also be a hot ...   Apr 5 2013, 08:09 PM
ChristopherB   Thanks Dave. I do have the Haynes manual, but the ...   Apr 6 2013, 07:56 AM
ChristopherB   Working on the car today and the throttle cable po...   Apr 7 2013, 11:20 AM
ChristopherB   I popped the cable back on the pedal. I think the ...   Apr 7 2013, 11:35 AM
ChristopherB   RE: Need help with my 2.0   Apr 7 2013, 12:04 PM
ChristopherB   I am ready to connect the ignition. I have a dizz...   Apr 9 2013, 02:36 PM
ChristopherB   here are the two connectors on my car.   Apr 9 2013, 02:37 PM
ChristopherB   I also have these two connectors on my positive ba...   Apr 9 2013, 02:41 PM
904svo   I also have these two connectors on my positive b...   Apr 9 2013, 03:58 PM
ChristopherB   Thanks. That could be it. Car doesn't have h...   Apr 9 2013, 05:37 PM
Dave_Darling   Those first wires are all aftermarket. Someone ad...   Apr 9 2013, 06:10 PM
ChristopherB   Thanks Dave and dpires, I don't know the color...   Apr 11 2013, 03:47 PM
- Lo-Fi Version Time is now: 4th July 2025 - 03:39 PM
