Question about plumbing Webers |
Porsche Rescue |
Apr 24 2003, 09:26 AM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am installing a 2.0 engine with Weber 40's fitted. This is my first experience with a carbed engine. It came to me with the fuel block/pressure regulator pictured below. It was marketed or made by PMO. It has a broken fuel barb and I need to repair or replace it.
My question: Is this a good system? It is "1 in/4 out", 2 out to carbs, 1 out to gauge, 1 out to tank. The return to the tank regulates the pressure with a hose clamp that restricts the outflow to the tank. Should I fix or replace this or is there a better system. Haven't checked to see what pump I have yet. It has been moved up front. Haven't talked to PMO yet either. Thanks for any advice. Expect more questions in the next week or two as the install proceeds (wiring? breather hoses?). Stay tuned. Attached image(s) |
Brad Roberts |
Apr 24 2003, 04:36 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Sorry Jim.
You replied while I was replying. On the CB pump: The rotaries are good pushers but bad suckers. So.. they kind of need to be mounted towards the front of the car near the tank (just like a 911) The Facet noisy pumps with the diaphram action suck and push very well. They can be mounted just about anywhere as long as they are mounted below the midpoint of the tank. The stock pumps dont suck very well.. which is why they are mounted as low as possible in comparison to the tank exit lines. B |
Lo-Fi Version | Time is now: 11th June 2024 - 12:30 AM |
