> Car just arrived and won't start '72 -- Solved!, Damn thing!
Jmedeiros
post Apr 5 2013, 09:21 PM
I just got the car delivered from TX and when it left, it was firing up with no problem. Now when I turn the key to run I hear the fuel pump and when I get to start, it doesn't engage the starter but fuel pump keeps pumping. Ideas?? (IMG:style_emoticons/default/headbang.gif)
silver74insocal
post Apr 6 2013, 09:33 PM
12.68 sounds low, disconnect the negative side a check again please. a healthy 12 v battery should read over 13 volts.
Jmedeiros
post Apr 6 2013, 09:45 PM
That was with the negative lead off.
QUOTE(silver74insocal @ Apr 6 2013, 08:33 PM) *
Jmedeiros   Car just arrived and won't start '72 -- Solved!   Apr 5 2013, 09:21 PM
ConeDodger   It's just shy. Rap on the starter with a hamme...   Apr 5 2013, 09:37 PM
Jmedeiros   It's just shy. Rap on the starter with a hamm...   Apr 5 2013, 09:53 PM
rick 918-S   Check the battery condition, Check the relay board...   Apr 5 2013, 09:53 PM
Jmedeiros   Check the battery condition, Check the relay boar...   Apr 5 2013, 10:53 PM
Spoke   Welcome to the madness. Banging on the starter or...   Apr 5 2013, 11:02 PM
Jmedeiros   12.68 volts on the Fluke meter. Welcome to the m...   Apr 6 2013, 09:14 PM
Vacca Rabite   If the battery is on its last legs, replace it and...   Apr 5 2013, 11:06 PM
Nico914   This happened to me tap on the big power relay att...   Apr 6 2013, 09:44 AM
Dr Evil   This happened to me tap on the big power relay at...   Apr 6 2013, 11:33 AM
Rand   This happened to me tap on the big power relay a...   Apr 7 2013, 06:49 PM
SUNAB914   Something to think about changing later is the ign...   Apr 6 2013, 09:54 AM
Jmedeiros   Two on order from PP. :-) Something to think abo...   Apr 7 2013, 01:28 PM
larryM   Go to O'Reilly's, Sears, or Autozone and ...   Apr 6 2013, 10:20 AM
Jmedeiros   I should also mention that the starter and battery...   Apr 6 2013, 09:29 PM
silver74insocal   12.68 sounds low, disconnect the negative side a c...   Apr 6 2013, 09:33 PM
Jmedeiros   That was with the negative lead off. 12.68 sou...   Apr 6 2013, 09:45 PM
silver74insocal   a healthy 12 volt battery usually reads closer to ...   Apr 6 2013, 10:35 PM
Jmedeiros   It's a brand new battery. a healthy 12 volt ...   Apr 7 2013, 12:43 PM
turk22   I had a very similar problem when my car arrived. ...   Apr 6 2013, 10:39 PM
Jmedeiros   I checked the resistance from the pos (+) side of ...   Apr 7 2013, 12:42 PM
Jmedeiros   Just tested the voltage on the yellow wire: 12.39....   Apr 7 2013, 01:07 PM
Jmedeiros   Looking in Haynes, it looks like I could jump 30 t...   Apr 7 2013, 01:27 PM
Jmedeiros   I just hooked up the remote starter (red to batter...   Apr 7 2013, 01:42 PM
r_towle   I just hooked up the remote starter (red to batte...   Apr 7 2013, 06:47 PM
ChrisNPDrider   If you can jump it from another car's battery,...   Apr 7 2013, 06:33 PM
ChrisNPDrider   What Rich said :beer2: I chased a "no start...   Apr 7 2013, 06:55 PM
ellisor3   You may have a bad (dirty or loose) ground somewh...   Apr 7 2013, 06:58 PM
Jmedeiros   IT IS ALIVE!! Turns out the starter was f...   Apr 7 2013, 08:37 PM
914itis   IT IS ALIVE!! Turns out the starter was ...   Apr 7 2013, 08:43 PM
- Lo-Fi Version Time is now: 30th April 2026 - 06:28 AM
