| Jmedeiros |
Apr 5 2013, 09:21 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 12-November 12 From: Los Banos, CA Member No.: 15,138 Region Association: Northern California |
I just got the car delivered from TX and when it left, it was firing up with no problem. Now when I turn the key to run I hear the fuel pump and when I get to start, it doesn't engage the starter but fuel pump keeps pumping. Ideas?? (IMG:style_emoticons/default/headbang.gif)
| silver74insocal |
Apr 6 2013, 10:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
a healthy 12 volt battery usually reads closer to 13.5. i am no expert with these cars but i would try a different battery, or take yours to o reilly / autozone and have them load test it. if it passes they will quick charge it for free in about an hour
good luck! keep us posted (IMG:style_emoticons/default/beerchug.gif) |
Jmedeiros Car just arrived and won't start '72 -- Solved! Apr 5 2013, 09:21 PM
ConeDodger It's just shy. Rap on the starter with a hamme... Apr 5 2013, 09:37 PM
Jmedeiros
It's just shy. Rap on the starter with a hamm... Apr 5 2013, 09:53 PM
rick 918-S Check the battery condition, Check the relay board... Apr 5 2013, 09:53 PM
Jmedeiros
Check the battery condition, Check the relay boar... Apr 5 2013, 10:53 PM
Spoke Welcome to the madness.
Banging on the starter or... Apr 5 2013, 11:02 PM
Jmedeiros 12.68 volts on the Fluke meter.
Welcome to the m... Apr 6 2013, 09:14 PM
Vacca Rabite If the battery is on its last legs, replace it and... Apr 5 2013, 11:06 PM
Nico914 This happened to me tap on the big power relay att... Apr 6 2013, 09:44 AM
Dr Evil
This happened to me tap on the big power relay at... Apr 6 2013, 11:33 AM
Rand
This happened to me tap on the big power relay a... Apr 7 2013, 06:49 PM
SUNAB914 Something to think about changing later is the ign... Apr 6 2013, 09:54 AM
Jmedeiros Two on order from PP. :-)
Something to think abo... Apr 7 2013, 01:28 PM
larryM Go to O'Reilly's, Sears, or Autozone and ... Apr 6 2013, 10:20 AM
Jmedeiros I should also mention that the starter and battery... Apr 6 2013, 09:29 PM
silver74insocal 12.68 sounds low, disconnect the negative side a c... Apr 6 2013, 09:33 PM
Jmedeiros That was with the negative lead off.
12.68 sou... Apr 6 2013, 09:45 PM
Jmedeiros It's a brand new battery.
a healthy 12 volt ... Apr 7 2013, 12:43 PM
turk22 I had a very similar problem when my car arrived. ... Apr 6 2013, 10:39 PM
Jmedeiros I checked the resistance from the pos (+) side of ... Apr 7 2013, 12:42 PM
Jmedeiros Just tested the voltage on the yellow wire: 12.39.... Apr 7 2013, 01:07 PM
Jmedeiros Looking in Haynes, it looks like I could jump 30 t... Apr 7 2013, 01:27 PM
Jmedeiros I just hooked up the remote starter (red to batter... Apr 7 2013, 01:42 PM
r_towle
I just hooked up the remote starter (red to batte... Apr 7 2013, 06:47 PM
ChrisNPDrider If you can jump it from another car's battery,... Apr 7 2013, 06:33 PM
ChrisNPDrider What Rich said :beer2:
I chased a "no start... Apr 7 2013, 06:55 PM
ellisor3 You may have a bad (dirty or loose) ground somewh... Apr 7 2013, 06:58 PM
Jmedeiros IT IS ALIVE!! Turns out the starter was f... Apr 7 2013, 08:37 PM
914itis
IT IS ALIVE!! Turns out the starter was ... Apr 7 2013, 08:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 06:26 AM |
