| Jmedeiros |
Apr 5 2013, 09:21 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 12-November 12 From: Los Banos, CA Member No.: 15,138 Region Association: Northern California |
I just got the car delivered from TX and when it left, it was firing up with no problem. Now when I turn the key to run I hear the fuel pump and when I get to start, it doesn't engage the starter but fuel pump keeps pumping. Ideas?? (IMG:style_emoticons/default/headbang.gif)
| Jmedeiros |
Apr 7 2013, 01:42 PM
I just hooked up the remote starter (red to battery pos (+)) black to the large spade on the solenoid & I get nothing. Sounds like a faulty solenoid. How do you bench test the starter??
| r_towle |
Apr 7 2013, 06:47 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I just hooked up the remote starter (red to battery pos (+)) black to the large spade on the solenoid & I get nothing. Sounds like a faulty solenoid. How do you bench test the starter?? You just tested it. On a bench, hook a black jumper to the negative battery and the body of the starter to give it ground. Then the red lead to positive and the large battery terminal on the solenoid. You may have a bad (dirty or loose) ground somewhere... Yoy need the battery to body connection to be super clean and tight. Battery ground terminal, clean and tight Ground strap at rear of tranny to under body...clean and tight. Then, use a screw driver to jump from the hot terminal to the spade (trigger) for the relay. Given the car was moved, and the key may have been left on more than once to turn the wheel....keep checking for grounds that are corrode (tranny ground strap) and fuses that shook loose etc. rich |
Jmedeiros Car just arrived and won't start '72 -- Solved! Apr 5 2013, 09:21 PM
ConeDodger It's just shy. Rap on the starter with a hamme... Apr 5 2013, 09:37 PM
Jmedeiros
It's just shy. Rap on the starter with a hamm... Apr 5 2013, 09:53 PM
rick 918-S Check the battery condition, Check the relay board... Apr 5 2013, 09:53 PM
Jmedeiros
Check the battery condition, Check the relay boar... Apr 5 2013, 10:53 PM
Spoke Welcome to the madness.
Banging on the starter or... Apr 5 2013, 11:02 PM
Jmedeiros 12.68 volts on the Fluke meter.
Welcome to the m... Apr 6 2013, 09:14 PM
Vacca Rabite If the battery is on its last legs, replace it and... Apr 5 2013, 11:06 PM
Nico914 This happened to me tap on the big power relay att... Apr 6 2013, 09:44 AM
Dr Evil
This happened to me tap on the big power relay at... Apr 6 2013, 11:33 AM
Rand
This happened to me tap on the big power relay a... Apr 7 2013, 06:49 PM
SUNAB914 Something to think about changing later is the ign... Apr 6 2013, 09:54 AM
Jmedeiros Two on order from PP. :-)
Something to think abo... Apr 7 2013, 01:28 PM
larryM Go to O'Reilly's, Sears, or Autozone and ... Apr 6 2013, 10:20 AM
Jmedeiros I should also mention that the starter and battery... Apr 6 2013, 09:29 PM
silver74insocal 12.68 sounds low, disconnect the negative side a c... Apr 6 2013, 09:33 PM
Jmedeiros That was with the negative lead off.
12.68 sou... Apr 6 2013, 09:45 PM
silver74insocal a healthy 12 volt battery usually reads closer to ... Apr 6 2013, 10:35 PM
Jmedeiros It's a brand new battery.
a healthy 12 volt ... Apr 7 2013, 12:43 PM
turk22 I had a very similar problem when my car arrived. ... Apr 6 2013, 10:39 PM
Jmedeiros I checked the resistance from the pos (+) side of ... Apr 7 2013, 12:42 PM
Jmedeiros Just tested the voltage on the yellow wire: 12.39.... Apr 7 2013, 01:07 PM
Jmedeiros Looking in Haynes, it looks like I could jump 30 t... Apr 7 2013, 01:27 PM
ChrisNPDrider If you can jump it from another car's battery,... Apr 7 2013, 06:33 PM
ChrisNPDrider What Rich said :beer2:
I chased a "no start... Apr 7 2013, 06:55 PM
ellisor3 You may have a bad (dirty or loose) ground somewh... Apr 7 2013, 06:58 PM
Jmedeiros IT IS ALIVE!! Turns out the starter was f... Apr 7 2013, 08:37 PM
914itis
IT IS ALIVE!! Turns out the starter was ... Apr 7 2013, 08:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 06:27 AM |
