> Fuel pressure, Solved !
914itis
post Apr 7 2013, 07:10 PM
My fuel pressure is set at 30lbs when the car is not running. When I start the car it read about 60 lbs. is that normal?
The car runs fine.
Djet 2.0 (IMG:style_emoticons/default/beer3.gif)
914itis
post Apr 8 2013, 05:42 AM
Thanks capt'n , I will try another gauge first. I tried to adjust the regulator and it only makes a difference when the engine is off . The gauge didnt move with the engine running as I turn adjust the regulator.
I think the fuel pressure regulator is the culprit. Are they generic? Can I get one from the FLAPS?
Admin please move this thread to the garage.
914itis   Fuel pressure   Apr 7 2013, 07:10 PM
euro911   Paul, nominal psi for a standard T-4 FI system is ...   Apr 7 2013, 08:23 PM
914itis   I have a Bosch 2 port pump, I believe it is stock....   Apr 7 2013, 08:30 PM
euro911   See if you can get a part # off the pump. Is your ...   Apr 7 2013, 10:02 PM
Cap'n Krusty   See if you can get a part # off the pump. Is your...   Apr 8 2013, 07:40 AM
Cap'n Krusty   The system runs at about 30 PSI. On shutoff, it u...   Apr 7 2013, 10:50 PM
914itis   Thanks capt'n , I will try another gauge first...   Apr 8 2013, 05:42 AM
914itis   Admin please move to garage.   Apr 8 2013, 06:36 AM
euro911   I don't know what '2-port' pump you ha...   Apr 8 2013, 11:50 AM
914itis   I don't know what '2-port' pump you h...   Apr 8 2013, 12:33 PM
914itis   Pump part # is 0580463010 I changed the regulator...   Apr 8 2013, 03:00 PM
SLITS   If you changed the regulator and the problem still...   Apr 8 2013, 03:43 PM
914itis   If you changed the regulator and the problem stil...   Apr 8 2013, 03:46 PM
SLITS   If you changed the regulator and the problem sti...   Apr 8 2013, 04:55 PM
914itis   [quote name='914itis' post='1847232' date='Apr 8 ...   Apr 8 2013, 04:59 PM
r_towle   Stock pumps are 65 PSI out of the box. Have you p...   Apr 8 2013, 05:00 PM
rudedude   If the car runs fine "The car runs fine....   Apr 8 2013, 05:06 PM
914itis   If the car runs fine "The car runs fine....   Apr 8 2013, 05:47 PM
914itis   You guys rock! You nailed it again :poke: . I...   Apr 8 2013, 05:50 PM
- Lo-Fi Version Time is now: 20th July 2025 - 11:01 AM
