| McMark |
Mar 14 2013, 10:30 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I have a 3.2 conversion project that's getting a 911 steering column for the key-on-the-left. Well this column we got didn't have the upper steering bearing and new replacements are $260. I was able to find something that will work for much less. Wondering if there is any interest in putting together some kits to sell.
These are not for 914/4 key on the right columns. It's a drop in replacement and should only take a few minutes to install. If there's interest I'll sell the first two at a steep discount as long as they get installed soon so I can confirm there are no installation issues or small variances from car to car. |
| laflaur |
Apr 8 2013, 09:26 PM
Member ![]() ![]() Group: Members Posts: 162 Joined: 8-June 06 From: Granite Bay Member No.: 6,186 Region Association: Northern California |
Ok,the bearing is in.
The shim part is the part you will need to address,not being attached to the bearing it wants to go before the bearing,and that makes it hard to get them even. I took the hose clamp and tightened it down wiith the shim around it ,got it started by taking a 32mm socket face toward the column and gently tapping a couple of times o start it,take off the clamp and continue to gently tap. The bearing will only go until it is even with edge of the column,probably because the shim is not even. I tried my monte carlo and stock wheel. They both seem to work fine,no binding and there is a BIG difference in the slop,like there is none left. I may remove it and play with the shim some more,maybe bond it to the bearing?....somehow |
McMark 911 & 914/6 Upper Steering Bearing Mar 14 2013, 10:30 AM
396 Yes..interested. Mar 14 2013, 10:50 AM
laflaur Hey McMark,
I have a factory 6 with wheel wobble,I... Mar 14 2013, 11:23 AM
sbsix McMark,
Interested as well....I have a NOS upper ... Mar 14 2013, 12:06 PM
edwin Slight hijack on this post but your pm isn't w... Mar 14 2013, 07:03 PM
oldschool I may need to 2... :blink: :popcorn: Mar 14 2013, 08:21 PM
McMark Looks like I have my prototypers. Thanks! :bo... Mar 15 2013, 04:15 PM
mharmon I'm interested as well. Mar 15 2013, 04:40 PM
ConeDodger I'm interested in the whole conversion. Just n... Mar 16 2013, 03:05 PM
Gint I'm in for one. Mar 16 2013, 10:51 PM
sbsix Well, it pays to be observant. My original bearing... Apr 7 2013, 09:24 PM
sbsix Mark's bearing is on the left and the OE beari... Apr 7 2013, 09:28 PM
sbsix Sorry for the blur, my camera doesn't like sho... Apr 7 2013, 09:32 PM
sbsix Mark, I'm open to suggestions about how to pro... Apr 7 2013, 09:39 PM
McMark Isn't there a tiny lip around the OD? You mig... Apr 8 2013, 01:14 AM
sbsix
Isn't there a tiny lip around the OD? You mi... Apr 8 2013, 09:29 AM
Harpo I would be interested in this as well
Thanks
Dav... Apr 8 2013, 06:11 AM
laflaur I am the other prototyper,and I am in the same spo... Apr 8 2013, 08:41 AM
laflaur I was able to get the original out by taking a thi... Apr 8 2013, 06:47 PM
McMark :trophy: Apr 8 2013, 08:05 PM
McMark I used a wide flat piece of metal to tap everythin... Apr 8 2013, 09:48 PM
laflaur yeah that what I was thinking,because it is not th... Apr 8 2013, 09:55 PM
McMark :agree: Yup. Just wast sure how to accurately exp... Apr 8 2013, 11:13 PM
sbsix Well my thoughts of finding a small bearing puller... Apr 13 2013, 02:30 PM
sbsix The above picture shows the column after the NOS b... Apr 13 2013, 02:33 PM
sbsix This shows the bearing just started. Apr 13 2013, 02:35 PM
sbsix This one shows both the shim and new bearing seate... Apr 13 2013, 02:36 PM
sbsix Another shot of the bearing and shim seated, from ... Apr 13 2013, 02:41 PM
sbsix One more of the completed bearing installation. Apr 13 2013, 02:43 PM
sbsix Steering wheel attached for a "slop" tes... Apr 13 2013, 02:44 PM
sbsix Old NOS bearing is on the left, and a brand new NO... Apr 13 2013, 02:59 PM
Britain Smith Will these bearings work in a '69 912?
-Brita... Apr 13 2013, 09:33 PM
McMark Britain, I need someone to try one out. PM comin... Apr 14 2013, 09:44 AM
laflaur sbsix,
great pictures and nice write up.
I failed ... Apr 14 2013, 02:40 PM
sbsix Thanks for the kind words..my steering wheel feel ... Apr 14 2013, 03:06 PM
jaxdream Just an idea to try iffin any of you guys have one... Apr 14 2013, 09:13 PM
sbsix
Just an idea to try iffin any of you guys have on... Apr 15 2013, 09:40 AM
McMark That's the right idea, but I suspect the diame... Apr 15 2013, 04:59 PM
db9146 Does anyone have the part number of the replacemen... Apr 1 2018, 08:46 PM
McMark I do. B:)
Anybody else want one at $60 ship... Apr 2 2018, 06:25 AM
rudedude I'll try one for my 911. Also need a crank po... Apr 2 2018, 07:31 AM
sbsix DB9146, the OE upper steering bearing does not cur... Apr 2 2018, 10:28 AM
db9146 Yes, since I bought mine several years ago, I have... Apr 2 2018, 12:52 PM
sbsix The OE bearing just centers the steering column. Y... Apr 2 2018, 02:52 PM
mb911 Does anyone know the retrofit part number on these... Jan 18 2019, 04:23 PM
mepstein I think it’s a shim and a bearing to replace the... Jan 18 2019, 04:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2025 - 08:46 AM |
