| pankopp |
Apr 9 2013, 05:51 AM
Captain Awesome ![]() ![]() Group: Members Posts: 62 Joined: 28-July 06 From: Acworth, Ga Member No.: 6,519 Region Association: South East States |
Hello everyone,
I am having a few issues with my Renegade conversion for the first time and cannot get my head around it. I recently did some work on my EJ22 Subaru motor involving oil pan replacement and a few changes to the intercooler setup, nothing major and nothing that should have affected the cooling system. (IMG:style_emoticons/default/dry.gif) My issue is that the car starts and warms up perfectly fine, but after it gets to operating temp (~185*) the thermostat opens, heats up the radiator, circulates coolant, and turns the fans on. Everything sounds normal, but after driving for about 20-25 min. I notice that the fans haven’t turned off ever since they initially turned on. Temperature stays around the normal operating level, may climb a little at a stoplight, but all seems normal. When I park, I have been checking the radiator end tanks and on the passenger side with the inlet and outlet coolant passages and the fan switch, the tank is very hot. The opposite side with no connections, just air release screw, is cold (ambient temp). It’s almost like the radiator is only flowing half the volume, as in passenger side half, not top to bottom half. Temperature outside her this morning was 54*, so there should be no issues. I have bleed, burped and refilled the coolant just as I have in the past. When I open the air bleed valve on the top drivers side of the rad. very little, to no air escapes, just coolant. Any ideas or recommendations would be a huge help. Thanks in advance! -Andrew |
| rick 918-S |
Apr 9 2013, 06:11 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,223 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
What type of radiator do you have? If both inlet and outlet are on the same side you should have a divider splitting the inlet and outlet tank. This forces the coolant over to the side tank that has the bleeder valve. The other advantage of this double pass style of radiator is it slows the coolant and aids in cooling.
pankopp Watercooled / Radiator Help Needed Apr 9 2013, 05:51 AM
pankopp The radiator is the brand that Renegade includes w... Apr 9 2013, 06:16 AM
JRust I would call Renegade & ask about it. They are... Apr 9 2013, 08:20 AM
pankopp I shot them an email with a few questions included... Apr 9 2013, 08:50 AM
kg6dxn On a dual pass radiator like this one. There is a ... Apr 9 2013, 04:02 PM
pankopp That's exactly what Renegade was thinking. Per... Apr 9 2013, 07:06 PM
Jeff Hail I have seen a lot of double pass radiators. A lot... Apr 9 2013, 08:00 PM
DBCooper It could be the radiator, and that's easiest t... Apr 10 2013, 07:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 11:22 PM |
